Spraying question-Kinda
Tom
I have a big kitchen that I am building with 70+ drawers, pull-outs, and doors. I spray ML Cambell Post Cat Lacquer.
This time I am going to borrow a pressure pot to eliminate constant cup filling. Not to mention the fatigue that comes with holding a full gun & cup. My question is can I leave the material in the pot,hose and gun overnight?
Re: Spraying question-Kinda
I have a friend who runs a small cabinet shop. I don't know the details, but he has a spray system that includes a "pot". My very poor grasp of the situation is that he could put several gallons of material directly in the pot, but what he does most often is set a 1 gallon bucket of finish inside the larger pot and spary out of that. Further, I believe he leaves it there for days on end. This way he only has to clean the gun and hoses when he changes what he is spraying and not the bigger pot.
If this seems unlikely according to your other reply's I could call him and get details.
Tom
Barry,
I would REALLY appreciate any additional info you could get for me. I think I have heard about the idea of use the 1 gallon pail inside the bigger pot. I also wonder if the kind of product makes a difference about leaving it?
Thanks!
Jason Roehl in Lafayette, IN
There's no reason not to leave the finish in there overnight, with a caveat. If you tip the pot too much (by accident or otherwise), you might get some finish on the underside of the lid near the pressure port--that you would want to clean off so that it doesn't get all gummed up. I'd clean the exterior of the gun to get all the dried finish off the nozzle area (doesn't hurt to do this periodically while you're spraying) before quitting for the day.
Enjoy. Pressure pots are the bee's knees. I find I can spray thicker material with them due to the positive fluid flow, and with thicker material, atomization doesn't need to be as fine, so I don't have to crank up the airflow like I would with a siphon gun.
Jason
No special technique--just stick the gallon can in the pot and put the lid on the pot.
If you're worried about the finish skinning over, you can put a little of the solvent for it in the bottom of the pressure pot, outside the gallon can, or even a little on top of the finish to form a liquid barrier (don't mix it in).
Finishes that have a "pot life", such as 2-part epoxies, can not be left in the pressure pot, lines and gun, as they'll cure without being exposed to air.
Jason
Tom
A few years back I built a kitchen for my brother-in-law. The finish was a color acrylic. It sprayed great. But I use just a cup. After d ays of spaying that was all it took to tear my Rotor Cuff!
Sgian Dubh
The answer is I suspect "No". I went to the ML Campbell website and read the Product Information for the EnviroVar Formaldehyde Free Conversion Varnish - 5% (see link below), which might be the product you're talking about. On the second page under Mixing and Catalyzing it mentions an 8 - 12 hour pot life. Some of their other post-cat finishes, such as the 2K Polyurethane has a pot life of three hours after mixing, so leaving overnight wouldn't be a good idea. It would be better to mix up what you need and spray it all out followed by cleaning up and starting again the next day. To work out roughly what you need allow for coverage of roughly 7 m²/ 1 litre of polish, roughly 70 ft²/quart.
Pre-catalysed lacquer is different and I've left this stuff in the pot overnight, and longer without problems. Slainte.
http://www.paintdocs.com/docs/webPDF.jsp?SITEID=MLC&doctype=PDS&prodno=035777112977&lang=2
no
I have sprayed lots of post cat Sherwin William and I presume your stuff is similar. Once the catalyst is added the clock starts. Product literature will give you a pot life number. Plus.....the catalyst is an acid and it is corrosive to metal.
I am puzzled by your problem. A quart cup will spray a "acre" of wood and it only takes a very few minutes to do it.
In my limited experience the people that use pots use precat lacquer.
Tom, I just read Jason's response. I think he is a pro painter and knows far more about this than I do, and he confirmed my thoughts and improved on them.
I will check with my friend later today and let you know.
As an aside; I will be curious about the affect of using a gun without a cup. Its true you don't have the cup, but you will have a hose, or is it two hoses? I will ask, but I don't think it will be as dramatic a weight lose as you expect. OTOH, there will be many advantages. just not having to stop every few minutes to refill the gun is great and making the finish up in larger batches is great. and being able to spray day after day with out having to set up and fill the gun is great. And the gun is more maneuverable. You don't have to pay attention to keeping it upright.
Tom
I use MagnaMax. and I was mistaken it is a Pre-Cat finish. The catalyst is added at the time of purchase. I believe is has can life of 180 days.
Rick Christopherson
If you're spraying lacquer for cabinets you need to switch to an airless sprayer. (That is the setup the previous poster was referring to but didn't know what it was.) The product delivery rate is much higher, and contrary to internet lore, the over spray is dramatically lower. The difference is that you are delivering pure product to the work surface instead of mostly air with some product.
Your mid-project clean up entails removing the sprayer tip....yup, that's all. The hoses and gun can stay charged for months at a time because they are completely sealed (just like still being in the can).
By the way, there actually is no mid-project cleanup because you can spray an entire kitchen worth of cabinets in a single day.
Professionals prefer a bucket-feed system, but for the occasional user, a hopper feed is actually easier to maintain because the lacquer is gravity fed. Re-priming the pump after several months of inactivity is easier.
yes, you can leave it overnight
Joe Burke
I've sprayed many gallons of precat out a 2 1/2 gallon pressure pot over the last 20 years. It's already been outlined, but place a gallon can containing what you intend to spray in the pressure pot, and replace the lid with the feed tube in the gallon can and away you go. Leaving the finish in the can overnight will not be a problem. And yes ... I've done this hundreds of times.
Now, having said that, there are conditions. Aren't there always?
It should be a short term thing. Not long term. There are plenty of things to keep in mind even in the short term. I apologize in advance if I'm stating the obvious, but better safe than sorry. Anything you leave overnight will need to be mixed before spraying the next day. If you've got an agitated pot then all the better. The viscosity may need to be checked and reset. Depends on the weather, local, time of year, product etc. etc. Rarely could I expect to arrive and start spraying the next morning without skipping a beat. When I left product in the pot overnight, I would depressurize the system, and drain the lines by blowing the product back into the pot. I used an air gun with a rubber tip because I never had any success any other way. I'd then hang the gun up well above the pressure pot to keep the product out of the lines. I'd plan on cleaning the tip and cap the next morning first thing. Just as well to do it first as opposed to starting to spray and then discovering everything skimmed over during the night.
Honestly, I found it just as easy to depressurize, blow the product back into the tank, and then replace the gallon can of finish with a container of solvent. Recharge the system and blow some thinner through the lines, and repeat the depressurization ritual.
Again, having said that, I've finished spraying a job like you described at 1:00 A.M. and closed down asap and walked off many a time. The world will not end.
As an aside, I forgot a cup gun half full of post cat for 3 days once and was surprised to be able to clean it up just fine. I'd expected a solid block of finish, and the need for a new gun. Typical? I dunno, but I don't want to try it again and find out.
clarify
"I've sprayed many gallons of precat "
The question involves post catalyzed material. Again, consult the product literature for "post mix pot life" data. The time will be strongly temperature dependent.
Re: clarify
Joe Burke
Read the 9th post down the list.
Save you the time. Copied and posted directly.
"I use MagnaMax. and I was mistaken it is a Pre-Cat finish. The catalyst is added at the time of purchase. I believe is has can life of 180 days."
