I have been working with wood for about 27 years now and I have seen the cost of wood go up and up over the years but it seems to be getting worse. I bought a piece of pine the other day it was 8' long and 8" wide and 1" thick. This is what the lumber co. is going by. So when I got home I measured the board and the width was only 7 1/4" wide where is the rest of it? I know it should have been about 7 3/4" wide.
It was 8' long is what I wanted but what a surprise in the width. Is this standard across the US with the lumber CO's? Being on a fixed income it is getting expensive to buy wood for the prices they charge and what you get to me it is a rip off. I live in Colorado and the town I live in there isn't much of a choice of wood. I all so notice that the wood was warped when it is laying flat it had a arch in it that too did not make me feel very happy.
Why can"t you buy a decent piece of wood any more without being warped or close enough to the size you want? It get"s to be very disappointing it almost makes you want to give up woodworking for the crap you are buying. Any suggestions?
1x8's and 2x8's have been 7 1/4 as long as I can remember, just as 2x4's are 1 1/2 x 3 1/2
I do recall there being some old 2x4's lying around our camp in Maine when I was a kid, those were 1 5/8 x 3 5/8
A few years ago I bought some 2x4's that were closer to 3 3/8" wide than 3 1/2", so you do have to watch it if dimension is important - most customers for this kind of lumber don't much care because the differences do not much impact structural carpentry.
Some yards sell pine at random width and length and even rough sawn, like a hardwood. That is the best way to avoid both the width problem and the bow/warp problem. Of course buying it this way requires more equipment to get everything straight - which is why S4S lumber is sold in home centers - most of their customers are not equipped to joint and plane boards straight and flat.
The downside to buying pine and stuff this way is that it tends to be more expensive than buying S4S 1x material from the home center. I can only assume that is because there is less demand for it across the market and that it tends to be clear lumber rather than #2. For all I know it is graded like hardwood rather than like construction lumber (I don't know much about grading).
Did you actually measure that it was 1" thick? If the width dimension is 7-1/4" then I'd expect the thickness to be 3/4". It's been like this for years as John said unless you go and buy rough lumber.
I'm always in awe of the price of clear pine since I seem to be surrounded with the trees.
You very often need to hunt through the pile for a straight piece and if you do find one, store it in the same condition that you found it until you are ready to use it. Bringing a piece into a warm, dry house that has been in unheated storage is a definite warping mechanism.
According to Wikipedia, the last change they made to softwood was in 1961.
"Early standards called for green rough lumber to be of full nominal dimension when dry. However, the dimensions have diminished over time. In 1910, a typical finished 1-inch- (25 mm) board was 13⁄16 in (21 mm). In 1928, that was reduced by 4%, and yet again by 4% in 1956. In 1961, at a meeting in Scottsdale, Arizona, the Committee on Grade Simplification and Standardization agreed to what is now the current U.S. standard: in part, the dressed size of a 1 inch (nominal) board was fixed at 3⁄4 inch; while the dressed size of 2 inch (nominal) lumber was reduced from 1 5⁄8 inch to the current 1 1⁄2 inch."
In Canada we get a specially treated wood that i call "Rock Pine"
It starts of as regular white pine, rough-cut to 2" x 12" x random lengths; It is then dressed to 11-1/4" x 1-3/8" to save us the trouble of dressing it ourselves.
This is then shipped to our local lumber yards where our highly trained and conscientious workers drive forklifts at high speed and try to stab the forks into the lumber pile to lift it, now you may not realize it but this takes and incredible amount of practice and is a lot harder to do than simply lifting it from under the pile.
Once the lumber has been offloaded then the real work begins; "Adding character"
Our trusty and artistic workers then set about to artfully distress the boring lumber. They put a lot of effort into throwing the lumber on the ground and dragging and scraping it to add the characteristic deep grooves and scratches of our "art wood" then they try to slam it around to see how much gravel they can get to stick, ( i believe the largest could actually be classified as rocks)
From here it is the thrown onto gravel lined racks in the damp leaky sheds in the yard to to "acclimatize" ( warp) and be "flavored" by the fecal deposits of the local bird and rodent community.
Delivery time the lumber is once again dragged out of the rack (further enhancing the artwork) and thrown into the back of....you guessed it, a gravel bed truck. The driver of said truck will then happily sign the work with a final tap dance leaving the beautiful imprint of his boots all over the lumber.
Upon arrival to your destination, the lumber will then again be dragged out of the truck and clunked onto the ground.
At this point the lumber is a real piece of art in every sense of the meaning;
It has no practical value at all.
It is truly representative of the world and time in which we live.
I always purchased lumber in quantity from large yards, but recently purchased some boards from a couple of local resale lumber yards and was appalled at what they delivered.
The lumber was unusable:
On a board of 8' length you can expect to spend 15 minutes digging out the gravel and wire brushing the board before you can pass it over a jointer and through the planer, you can the expect to dress 3/8" off each side to clean and straighten it up. So a board that started life full of promise as a beautiful piece of crisp clean 2" thick pine is reduced, by abuse and ignorance to a mere 3/4" of usable wood. What an absolute waste of time, material and money; why bother dressing the lumber if you are only going to make it unusable by mishandling it.
I can only conclude;
This lumber is sold to some kind of "woodworkers" that don't use cutting tools of any description, handtools or machinery.
That the company owners and workers have never done any woodwork, certainly never used any machinery or had to sharpen jointer or planer blades, and certainly have never used a handplane.
That the company owners do not provide any training to their workers, either because they dont know the difference or simply don't care.
I guess It boils down to the fact that, they will sell it if we keep buying it, but I am a little confused as to who would use lumber like this and how you would use lumber like this.
There is actually some truth to this part - I've seen the drivers at big yards stab the units of sheet goods with their forks to cut the bands on a new unit
Rule 1 Before picking up a stack, first go to the parking lot and till it. Return to lumber pile being careful to not jiggle the rocks off the forks. Then lift the tallest stack to be found so as to embed said rocks as deep as possible into the bottom layer of the lumber. To disguise rocks it is best to get a bit of dirt along with the rocks.
The yards are not all like this. The better managed are as careful with their lumber as we would be. Baillie Lumber is a good example of a well run mill..
I pulled up beside an 18 wheeler hauling lumber on the Interstate a week or so ago. As I always do, I checked out his load. It was construction grade pine. I've been looking at pine 2 X 4s all my life and, after 70+ years, I think I can identify a 2X4 by sight. I didn't recognize the lumber on this truck. All of it was of uniform thickness that looked to be noticeably less than 1 1/2" thick and 8 to 10 feet long. While I was puzzling over what it was, it struck me that it was a load of "2X4s" destined for someone's new dream home. I wonder when the economies of milling lumber will begin to threaten people's lives. I wouldn't want to live in a structure framed with 1 3/8 X 3 3/8 framing material.
Although you can only see one hole from this position there are in fact two holes in the top of this crate and an expensive piece of machinery inside, which they managed to hit and damage.
Yep, I am one of the grey bearded old timers now, built my first home in the early 60's, as I recall the "2 X 4's" I used were about 1 3/4 X 3 5/8" which irked me at the time as the home I was raised in was built in the early 1900's and had actual 2 X 4's (actual measurement was rough sawn 2 1/8 ~ 2 1/4 by 4 1/8 ~ 4 1/4"). However almost all the studs were arrow straight and very few had large knots. (those with large knots and that were not straight were returned to the yard without them making any protest). Cost of a standard stud was about $.99.
When I built my shop about 10 years ago I used "2X6" studs for the walls. I did buy them from the Borg's but hand selected every board. I made several trips to obtain the full number of boards I needed as the ratio of acceptable (to me) vs junk was about 1 in 6. Don't remember the cost of the 2X6 X 8 now but they were substantially more costly.
I would not attempt to build any furniture or cabinets from "finished" lumber. I have purchased all of my hardwood lumber in the rough ~ much of it air dried and obtained from Estate sales (mostly from Amish estates). On occasion I have purchased kiln dried from a local sawmill, it is acceptable but the Amish material is actually much better, as the Amish select large ~ often old growth trees ~ cut and pulled out individually and sawn on their own mills.
The local Amish have knowledge of how to select the trees, saw, stack, dry and store the material properly and the results are great. Several times I have purchased a stack of lumber and find it is an entire tree carefully stacked separately. I have one stack about 4' X 8' x 8' of figured Cherry with some boards as wide as 24" that is from one tree. Think I paid about $140 for the stack at an auction.
The standard nominal size for softwood construction 1x8 lumber is 3/4" x 7 1/4". You will pay for the nominal size, not the actual size. Hardwood furniture grade lumber can be almost any size.
Living where you do, it may not be possible, but I would not purchase dimensioned cabinet wood. My approach is to buy the minimum order of one wood, around here cherry, buy oversized; or chainsaw mill my own wood. I currently have a lone on a free 24 inch maple, and an 18 in cherry; or I do projects like green wood (chairs, tools, etc...), or tuning that use essentially fire wood; Or I build guitars which even when you work from the raw materials, they are essentially sold as kits. So if you bought a kit, the back piece would come cut out, meaning it could distort; or you get the raw, wood and it needs the profile cut, and some thicknessing, pretty much the same deal. One isn't starting from logs.
These approaches are not cheap either, mostly in storage, but at least one ends up with usable wood. If I couldn't afford wood I would restrict my projects to instruments or stuff you can do with found wood. The funny thing about wood is that most people are actually trying to get rid of it.
This is a pic of the cottage across the road it is going to get torn down, and a real house put up. The wood has been sitting there for a few months. That is thousands of dollars of rock maple, one could have got a lifetime of bowls. Or if they hadn't been cut so short, almost anything. They can't get rid of it apparently. One street north of here, there was a small subdivision put in. The place is called Orchard road, and yes, there was an orchard. I didn't want any apple at the time, but I cut out some titanic slices of maple. "Lumber" refers to the fact wood is a burden, it is actually free.
Hank, I wouldn't want to work with that either. I don't really know why, but it seems hard enough to hit 7/4 on edge when hanging the drywall. Up here I think they may now require 2x6 for exterior walls for insulation purposes, so it does raise the question what they are still using the small stuff for, could be interior walls. There is more than enough strength in the wood. it only takes 10 square inches to support second story and attic and roof loads for 9 feet of span up here. A lot of those snazzy FLW house were pretty cheaply built and all they had for structural walls was the boards in the board and batten walls. But when you do the math it ads up to a lot of square inches.
Here in Wichita every 2 x 4 in the piles at the big box stores has the pith running down its center (approximately in the center, that is). They proudly advertise this as "center cut". They also sell short studs so no one has to go to the trouble of cutting off the ends to make an 8 foot wall. In a later post it is noted that the fork lift jockeys try to break the straps on the bundles with their fork. I think this is a self preservation measure because most of that crap warps so badly that it may wrap around your neck if you are nearby when the straps are cut. Who knows - maybe busting the straps with a fork lift is an OSHA requirement now.
