The Saturn 5 J-1 rocket engine
PIC 1
On a recent trip we stopped at the Marshall Space Center/US Space And Rocket Center. If you were fascinated watching the race to the moon this place is better than Kennedy in Fl for studying the rocket portion of the project.
Upon first seeing the massive Saturn 5 engines during launches I wondered how they worked and what all the strange looking parts did. As luck would have it there was a Rocket Scientist docent at the rocket center to answer what ever questions I could think of.
PIC 2
It was explained that the J=1 engine for the Saturn rocket was an unsophisticated "simple" engine by today's standards. Kerosene fuel and liquid oxygen is pumped to the engine by two gas driven 60,000 HP turbo pumps at a combined flow of over 9,000 pounds per second! That is a number that is hard to get one's head around. The picture shows the fuel distribution plate for the combustion chamber of the turbo (top) and part of the fuel distribution plate for the main engine(bottom).
PIC 3
The thing that looks like an intestine wrapped around the main rocket nozzle is the exhaust port from the upper rocket engine that drives the turbos. Its exhaust is delivered to channels in the "skirt" of the main engine nozzle (skirt removed from the engine in this picture). This relative cool exhaust gas cools the skirt. The gas is "cool" because heat has been taken from it to be converted into work to drive the turbos.
The kerosene is pumped through tubes covering the shell of the main nozzle before injection into the combustion chamber. This kerosene cools the nozzle and heats the kerosene prior to injection through the injector plate. The more heat that can be sucked out of the combustion process, the more work the engine can deliver.
The nozzle assembly is brazed all at once in a giant brazing furnace that sticks all these parts together.
They said that when they tested the Saturn 5 engine assembly it shook Huntsville and caused substantial damage. Tests were moved to a more remote location in MS.
Re: The Saturn 5 J-1 rocket engine
Larry Barrett
My first job after graduating from school in 1964 was with IBM in Huntsville. IBM built the IU - the Instrument Unit - that sat on top of the 3d stage of the Saturn V rocket. That was quite a time. Hard to believe that the entire development process leading to trip to the moon was accomplished in a few short years almost 50 years ago.
Jesse Cloud
And a lot of the work was done with slide rules! Still have mine somewhere...
What a job at what a time!
I didn't take a picture of it but they have your unit beside the J-1 engine. There is "nothing" to it. All that rocket and this insignificant (by rocket length) ring controlled the whole affair. I showed the neatly wrapped wire harnesses to wife. My mother wired for Bendix aviation.
Re: What a job at what a time!
Larry Barrett
It did seem like there was nothing to it. The fuel tank of the S-IV stage is what filled up the interior of the IU ring.
I still have my slide rule and get it out occasionally just for fun. I can remember when my department got an electronic calculator. It had a 4 line CRT and was as big as a small suitcase. We had to share it among a couple dozen engineers, so the slide rule was handier.
Jerry Roberts
I worked on the Saturn 5 many years ago.I happened to work on the s4B, third stage and all the hardware that interfaced with the spacecraft That was at Kennedy Space Cntr. I started working at the Cape(Cape Canaveral) right out of high school,57, as a electronic technician and finally quit due to lack of work in the early 70s. I could tell you a lot of stories about those early days at the Cape. I miss it terribly.
Fantastic stuff. My dad was a farmer but went to school with Christopher Kraft (SP?) one of the leaders early on in the program. My cousin worked at the Cape on the Mercury Capsules. Told a story about the fact that they had to account for EVERYTHING they carried in and out. They were terrified someone would leave a loose screw or tool to rattle around in the guts. One day they looked around and someone had left an 87 pound beam behind, loose.
PS
The red pipes are for liquid oxygen. The turbo pump is just above them. The 60,000 HP rocket engine to drive the turbo is behind the turbo. In this picture you can see the tubes on the rocket nozzle that carried the kerosene over the surface to cool it and heat the fuel.
Didn't ask what the small pipes from the exhaust below the turbo were for. Maybe they pressurized something internally in the engine as this area would be at elevated pressure as well as temperature. Its all a lot of plumbing to transport all that fuel.
Correction to above: fuel consumption is 3 metric ton per second or about 6000 pounds not 9000.
John McGaw
Probably more telling is that the Saturn V could have lifted the entire mass of the International Space Station (419,600 kg when completed) into low-earth orbit with only four launches (payload 118,000 kg) instead of all the dangerous expensive space shuttle flights. The Saturn V had a 100% success rate in mission launches.
Not rocket science
Dick Coers
but I started as a draftsman in April 1973, and then a designer, at Caterpillar when they tried putting gas turbine engines in a tractor scraper and a wheel loader. We had two 4 function Wang calculators in the corners of the room, but everyone else was on slide rules. Finally, HP calculators came in. It was a real education for this farm boy to design with materials like Inconel, and Waspaloy. The idea that cooling air was 1400+ deg F was also a strange concept. We did get test machines operating, just a few years after Chrysler stop throwing money down the hole to put one in a car. We designed stationary units after that, then Caterpillar bought Solar Turbines and got into the huge engines. The hair still comes up on the back of my neck to hear a turbine spool up!!!!! One last story. One day we heard all the fire alarms go off in our building, adjacent to the test cells. Like most engineers, you go to the fire, not away. We had a run away engine, it was eating itself up and the melting metal was causing the turbines to run away. No one had thought about an air damper to starve the engine. They finally filled it with water since the engine was a total loss anyway. Okay, one last one. We needed huge amounts of test air for much of the component testing. The facility engineers designed in a gigantic Brown Boveri compressor. I don't remember the horse power of the electric motor, but the utility company required 8 hour notice before starting it so we wouldn't starve the grid.
Alexandre Grigoriev
Jeff Bezos (Amazon CEO) organized an expedition to retrieve the spent F-1 engines from bottom of the ocean.
Yep, used one almost every day for a few years, still have one, pretty good as a straight edge for drawing lines :)>.
