I have a vacuum pump system that I have used for a number of years. It works great to finish the bottom of bowls. Normally when there is nothing on the lathe the gauge reads zero. Lately it has been reading 7-10" even when it is not connected to the lathe. I took the hose off and it read zero. As soon as I put the hose back on it read 7-10". I tried a new hose and it read the same even with nothing on the other end of the hose. Does any one have any ideas what is causing this or how to fix it?
It may be that your pump capacity exceeds the propensity of the hose to keep up. What size is the manifold, and hose size.
Unless you are in Death Valley or somewhere below sea-level, you only have a maximum atmospheric pressure of about 14 psi, which is not a lot.
Keep in mind that the area of a circle / hose quadruples when you double the diameter, so if you are trying to use a 1/4" hose, but then increase up to 1/2", at that same pressure, it will pump four times as much air, so your gauge probably just indicates that the hose is a restriction.
I am using the same pump, hose and connections that I have used for a bout 10 years. I can get about 28" of vacuum when I have a bowl on and a good seal. The only thing that has changed is the amount of pull when nothing is connected.
Where is the gauge connected? Sounds to me that it is between the vacuum pump and the lathe and there is a slight blockage in the tubing on the downstream side of the gauge so enough air can't flow into the pump to drop the vacuum to zero.
Do you have a filter in the line that might be plugged?
Like figuring out electrical problems, the best way, is through process of elimination. You stated, "I took the hose off and it read zero", which indicates the problem is in the hose. Maybe you have a wood chip or something down in it, but your other hose trial should have proved that wrong.
If you have a larger hose to try, I think you will see what I'm trying to share with your in the earlier post.
I don't have a filter on it. I thought it might be a blocked line so I got a new one. It gave the same results. Maybe I should try a different new hose.
Assuming that the gauge is at the pump end of the rig and based on the fact that the gauge reads 0 when the hose is disconnected then the only reasonable thing left is the rotary coupling arrangement that feeds vacuum through the headstock and to the chuck. It would only take a few wood chips (or a bit of torn gasket material) to block that thin tube and raise the vacuum reading. I don't know how your rig is set up so it might be easy (straight) or difficult (right angle) to clean out.
I have a vacuum pod set up to hold my guitars. Very similar to your lathe chuck but doesn't need to spin. I had a similar issue once and found that a little wood chip had gotten lodged in the hole of the plate. It didn't make it into the tube. You might check that in your setup.
I suggest that you buy a new gauge. The sensing portion is a flexible envelope of thin brass that expands and contracts with pressure changes. By any chance did residual moisture freeze with our wonderful winter weather. Also there are some fine gears similar to a mechanical watch. If a new gauge fixes the problem do an autopsy on the old one. You will then understand my comments.
Has it really only been happening lately, or did you just notice it lately? I'd be it's been happing all along, and you've just noticed it.
What's probably (been) happening is that the hose is restricting flow enough to register on the gauge. Even if the hose is the same diameter as the pump's fitting, there'd still be a flow restriction due to air friction - just the same as there's flow restriction in a water or air pressure hose over distance.
