Filling Veneer Tearout in Marquetry
don stephan
This chestnut burl veneer looks perfect for a marquetry field, but the veneer has some tearout too deep to sand out. I'm hoping the offcuts will have some of the tearout for experimenting. I've used Famowood filler before with good results, but the tearout is very shallow and I don't know how well the Famowood will bond without any mechanical grip. CA glue has been suggested as an alternative, but I've never used it as a filler, only to stop cracks when turning bowls. Should I try medium CA, or even thick, for this relatively shallow tearout about as wide as a dime, and in one coat or several?
Re: Filling Veneer Tearout in Marquetry
You could fill it and then paint the missing grain back in, or you can patch it. Either way can yield a fine looking result. If you fill, make sure the filler material doesn't get into the grain of the adjacent veneer.
I don't have any great recommendations for filler. I use waterbased wood filler for rougher stuff, but it works fine as a grain or small repair filler. On smaller defects, we often used shellac sticks. Water based filler takes grain paint nicely, but I don't know what to expect of its longevity or susceptibility to environmental factors like relative humidity.
Gary Smyth
You might want to check out Mohawk products. The moving companies use them to do easy to serious repairs on furniture. They have wood color markers, fill sticks, epoxy, putty, stains, dyes, lacquers, glazes and even leather repair items. Not too expensive unless you buy multiple products in a color range, and full kits in some categories can be as expensive as a big router. They sell a multitude of colors throughout the wood color range -- over 100 shades of fill sticks. I can't get a link to display but if interested try: Mohawk furniture finishing products. 2nd listing down. There are also videos on how to use some of their produces either linked through their site or on You Tube
Re: Filling Veneer Tearout in Marquetry *LINK*
Bob Entwisle in NJ
Here is a link to what the products Gary mentioned.
Bob in NJ
Mowhawk - Touch-Up Fillers/Wood Fillers
