INCA 259 table saw with mortising table and stand.
Mark Nowicki
Just bought one.
I will pick it up in Ottawa this week, I know LeeValley used to sell them. In 1986 this model sold for $1600.
Any comments , advice, or warnings appreciated.
Mark
Re: INCA 259 table saw with mortising table and stand.
Nice saw
... but it has a metric arbor and standard US blades won't fit. If I remember correctly, those saws have a tilting table instead of blade. That would be worrisome, too, although a lot of old heavy iron tablesaws worked that way.
A buddy of mine had one of the Inca TSs early on, back in the late 70s, and they put up with it for a while and ended up trading it for a more conventional saw. I can't recall any other details about it.
Your mileage may vary, but I've had mixed experiences with Inca machines. I have owned a bandsaw and two jointer/planers of theirs. Hated the bandsaw and loved the first jointer/planer. The newer version has some engineering clinkers, in my opinion.
Satisfied customer
Paul in NJ
I have owned one for 25 years. A great little accurate saw. I have ripped miles of boards on it and never had a kick back due to its well-designed riving knife. You move the table up or down to adjust the height of the blade and it can be a little slow to do so. Mostly I leave the table at its lowest position. You also have to tilt the table to do angled rips. It is somewhat of a pain but I find I don’t do them too often. The table is really too small to do much plywood work, I wind up having the sheet ripped to 24" at the store to make it easier. I have an 8” Forrest combo blade, they will bore it out to the required 20 mm for a nominal charge($12.00 if recall correctly). The mortising attachment works well but it is a little light for large things like house size door joinery.
I paid $1000.00 for the saw on close out without a stand or motor. I have never regretted buying it or the 10-1/4 combo jointer/planer. The two have built a houseful of trim and millwork along with a lot of furniture.
Paul Dzioba
Re: Nice saw
TomD
To state the obvious, you have to want what they are, and what they are not is interchangeable with large US table saws, contractor, or cabinet.
They do have a 20mm arbour. I have a metal lathe, and I just bore the blades out. Maybe they arbour could be recut to 5/8. I haven't looked into that.
I had to disassemble mine it was all clogged up with dust. But it works better since. I am taking about some major parts, not requiring huge disassembly, and hour or two.
If you want a light saw, that is super accurate, and has a small footprint. go for it.
In good nick it is about 400 dollars. I sold one in Toronto last year that had the hor mort, and the sliding table (makes the saw huge). I was in good conidtion except the mortiser was seized, so it just needed some play with wd40, no biggie. The 2hp motor was worth what I asked for it.
If you want to knock some money off, you might see if the mortiser has hold downs, I have never seen any...
If anyone wants the bandsaw or jointer, I have them in toronto
Re: Nice saw
Mark Nowicki
Small footprint, portability and accuracy is the reason I wanted one.
I got rid off my North American style table saw about 20 years ago without any regrets. I use a bandsaw to rip, a Festool track saw to break down sheets (apparently Festool blades have the same hole size), and a RAS for crosscuts. I hate routers.
The INCA will be used mostly for joint cutting. It appears to have the hold downs, and the micro adjust for the fence.
If you can, e-mail me more info about the jointer and the bandsaw.
Thanks
Mark
Re: Nice saw
TomD
can you mail be back at proaconstrictor at yahoo dot ca
(Same for the guy who wanted info on the Masterpiece catalog, if still out there.)
It is the large jointer, and the small bandsaw. There are extra blades for both.
Re: Nice saw
TomD
"I got rid off my North American style table saw about 20 years ago without any regrets. I use a bandsaw to rip, a Festool track saw to break down sheets (apparently Festool blades have the same hole size), and a RAS for crosscuts. I hate routers."
Minus the festool that is pretty much me in a nutshell. LV used to do the blades, they may even still have stock, they don't by any means have everything in the catalog.
