REAL MILK PAINT
Chair repair question
robert henderson
My neighbor has asked me to repair his dining room chairs.
The front legs are each held on by two hanger bolts through a wooden bracket that is set diagonally across the side and front members of the frame.
The bracket ends are grooved to fit matching grooves in the inside surface of the frame members.
Picture is of a similar arrangement
The brackets are shot and need to be replaced.
I assume the grooves are there to create more glue area but I do not think I can make a snug fit with my skills and equipment so I'm looking for alternatives.
Would it still be strong enough if I
a. just glued and screwed a new bracket over the grooved area (reducing glue area by about half)
or
b. Plane down an portion of the grooved area on the frame members so I have a flat area to glue and screw the new bracket to.
or
c. any other idea
Thanks
Re: Chair repair question
Shot?
Sorry, but I don't understand what is wrong with your brackets. You say they are shot. What does that mean?
Regardless, doesn't matter. Corner brackets with corner bolts were designed to make chair construction cheap. I've not seen grooved, matching bracket/rail design but it makes sense. Glue lines can only stabilize this joint. The pulling power of the hanger bolt is the prime mover, although the photo shows a screw.
If you really need to replace the corner brackets, I would definitely just pare off those ridges and give youself a solid interface.
Re: Shot?
robert henderson
Thanks Ellis. I will plane down a flat spot.
By shot I meant
1. The chairs I'm dealing with was manufactured with the screw holes for holding the bracket to the rails about half the distance from the ends as those shown on the chair in the picture. So most of the screw holes have blown out the end grain and have become chewed up slots.
2. Thereafter someone "repaired" the chairs with screws, nails, Gorilla glue and anything else they could lay their hands on.
The only way I can see of making the original brackets work is with massive amounts of epoxy.
Time for new ones
If they're blown out, I'd go with new ones. Sounds like not a lot of work.
Use new screw hole locations.
Re: Shot?
Yonak
Do I understand correctly that the holes in the brackets are elongated and will not hold the head of the screw any longer but the screw attachment into the legs is sound ? If so, how about just putting some metal plates (or fender washers) over the faces of the brackets, so the screws have something to hold onto ?
If replacing the brackets, rather than cutting off the ridges, maybe you could fill in the grooves with wooden strips. It may be easier.
Re: Time for new ones
Bruce, a MN Galoot
I did exactly that repair on a set of old, not antique, dining chairs a few years back. It truly isn't that hard to make new braces, slots and all. I told my customer to get a new set of chairs, but they were his mother's, so you know how that went.
Ralph Lipeles
Can you sand the surfaces with coarse paper and then use an epoxy as opposed to a wood glue. The epoxy will gap grooves and still provide a strong bond.
Re: Shot?
Keith Newton
Robert, Under these circumstances, I've found the thin or fast CA to be a good alternative. If you can set the parts up where you can fill the holes from above, until they won't take any more. It will saturate the surrounding wood, and become a plastic plug, which you will need to drill a pilot hole into, to even get a screw of any size in.
Or you can just fill the holes, then flip it over to drain the excess, then get new oversize screws to replace the old. This gives a nice plastic bushing of sorts for the screws to bite into.
I've probably used hundreds of gallons of epoxy, but don't think the normal stuff penetrates or locks in quite as well as the CA. If you have a hobby store that sells model airplanes, they will probably have the good stuff.
penetrating epoxy *LINK*
Jerry Gibbs
GIT-Rot has been around a long time.
GIT-Rot
Re: penetrating epoxy
Keith Newton
Jerry, I have not used that brand, but have been using the Smith brand CPES which also has been around for a long time. However I normally buy 2 quart size, and I figured the price on that amount would be prohibitive, and the cure time is pretty slow, while the CA is instant.
Also, I see Jamestown Distributinghas dropped the smith brand, so I guess I'll be trying their Boatlife brand next time I order it.
