OT - Any TV repair people out there.
Ralph Lipeles
I have a problem with the volume on one of my television sets. It is connected to a Motorola cable box. The volume has a range of 0 to 100. I usually have it around 24. Recently the volume keeps changing. There are times that I have it at 100 and can barely hear it. A minute later the sound gets so loud that it is deafening. I don't know if the volume problem is caused by the cable box or the television.
I have a pair of external stereo speakers that I never use. I thought that if I connected them directly to the cable TV box I could determine if the volume problem was caused by the cable box or the TV set. So, I purchased a 24 foot length of "speaker hookup wire" on eBay. I figured that I could cut it in half and hook up the 2 external speakers. Unfortunately, when I did that I got no volume at all. So, I brought the wires to my workshop and checked out the continuity. Each wire has an RCA jack on the end. I am used to having the hot part of the RCA jack connected to the center electrode and the outer shell portion connected to shield or not connected. The wire that I bought are backwards to what I was expecting. The outer shell is connected to the wire. The center pin is not connected. Is this normal?
Re: OT - Any TV repair people out there.
Hoa in Alameda
I don't know about the problem with the TV's audio.
About why the external speakers makes no sound when connected to the cable box: the audio from the cable box is not designed to drive speakers. You need an amplifier between the cable box and the speakers.
del schisler
is the volume only changing on the tv ? the numbers going up and down on it's own ? than problun is in the tv set, if the volume number are changing on the box or staying the same and no volume with the number on the tv turned up , than box is the problum, if this is only once in a while i would change the box first, but like i say if number is changing on tv by itself than tv is at fault, the signal out of the box has to have a amp. hook up to the output, like as mention , i was in tv repair for 50 yrs but retired now good luck
John McGaw
To qualify my remarks, I was a broadcast engineer among other things during my misspent youth.
Simple way to determine if it is the TV or the feed, is to provide a different feed. Hook up an antenna of some sort to the back of the TV, a piece of wire will do in a pinch, and watch some broadcast TV for a while. If the volume is stable then the problem is with what is coming from the cable box. If it still varies then it is the TV.
Alternatively, if you have a DVD player hooked to the TV, check to see if the volume varies during DVD playback. You would want to try this with all of the TV's inputs since some sets have a per-input volume setup.
There can be a complex interaction with TV sound in many modern setups and the internal options in the sets sometimes don't allow much fine control. My setup has a sound bar hooked up to the TV by a fiber optic link but the TV's options hide the needed settings for this sort of external audio and reverse the sense of some toggles. Then I have an interaction between internal volume control of the sound bar and the TV (and the DVD player and the connected computer for that matter).
Bill Howatt
The signal out of the set-top box is likely what is called Line-Out and as was said needs an amplifier because it is only about 1V. You should be able to connect a pair of head-phones or those little buds directly to it though and hear the sound.
Volume levels between channels, commercials, people-whispering/talking on shows, movies etc does drive me nuts but your case sounds pretty extreme.
I don't think anybody should get any Oscars, Emmy's or other awards for sound until they make the sound in programs such that I can always hear it without monitoring the program with the remote control in my hand to adjust the volume. Alright, so I'm old!
Bill
Might be a simple remote control problem also. I have had some become intermittent. Actually have one that is (not in the audio section) at the moment. Shouldn't be hard to check out, if you have multiple remotes, move all one out of the room, if still happening, at least you have eliminated one possible problem.
Lee Gordon
Lee Gordon
The simplest way to test whether your problem is in the cable box or the TV is to hook up a different TV to the cable box. If the problem persists, it's in the box. If the problem goes away with TV #2, the fault is with TV #1.
Ralph Lipeles
I did almost what you suggested yesterday. I swapped out the box for another. It was a lot easier to swap the box then to swap the TV. The volume with the other box was good. I called Frontier and a new box is on it's way. All that I will have to do next is the 1/2 hour phone call to set up the new box. I do not know why they don't do that before they send them out, but they don't.
