A55 Smoothing Plane
OT-Under car washer?
Tom
Wondering if anyone has made a washer for cleaning the underside of your vehicle? Thought it might be something to fabricate when and IF Spring comes!
Re: OT-Under car washer?
Ralph Lipeles
I had a friend that made one quite a few years back. I believe he used 1/2' copper pipe. There was a section with a fitting on the end that connected to a garden hose. The other end was soldered to a T fitting. There were sections that connected to each side of the T. They were 2 1/2 to 3 feet long so the section would fit between the wheels. There were caps soldered to the ends of the side pieces and holes, pointing up, drilled in the side pieces. Thinking back I believe that the design would be better if there was a long section of pipe between the T and the side sections. That would let you push and pull the washer under the car instead of having to drive the car forward and back.
Bill Howatt
I just go down to the local car-wash, not a drive-through, that has a wand. Select the high-pressure rinse and blast away in the wheel wells and roughly under the car. After you drive through some rain, especially heavy rains, you've achieved the same thing, IMO.
Bill
John McGaw
I saw a rig someone made in Anchorage for cleaning the Winter from the bottom of his vehicles. It was just a 6-foot piece of PVC fitted to a tee with maybe 12" sticking out on either side, capped at the end, and with small spray holes drilled into it. The idea was that it was to be hooked to a hose and slid under the vehicle to spray upwards. No idea of how well it worked.
