Gun stock refinish question
The finish on my uncle's Ithaca 37 is largely gone. I hunt with this gun so it needs protection. I have the bulk stripped and sanded, but, what to do about the checkering? I will apply Tung oil to refinish....many coats as needed. But what do I do about the checkering before proceeding?
Re: Gun stock refinish question
John in NM
You can get checkering tools at Midway USA for cleaning it up - or I could lend you a couple, I rarely use them. You can even make them yourself if you prefer it - just like a tiny float filed to a V rather than flat.
Once cleaned, go over it with some thinned oil, just a couple coats. If you do more on the rest of the stock, go around the checkering.
EDIT:
Looks like they only carry the more popular DemBart tools now. They used to have a less expensive line too. You only need a single line tool for cleaning up existing checkering. I can take pics on Wednesday if you want to see the kind you can make yourself - the ones of those I have were commercially made, but the principle is very simple.
follow up
I brushed the checkering with a tooth brush and solvent and it cleaned up satisfactorily. I think I will lightly oil it and leave it alone. The rest of the stock is drinking oil as we speak.
Re: follow up
I also have a checkering tool, but have never had to use it to clean up checkering when refinishing. I used to use BLO on all my stocks, but now use Pure Tung oil. When I was young and did a lot of Squirrel hunting, my rifle probably had 40 or 50 coats of BLO applied. At that time I didn't have much (hardly any) money, so cleaning was done using kerosene or Naptha (mother used it for clothing spot removal), with a short section of fishing line, a Bobby pin on one end and small rag on the other. My lubrication was either motor oil or 3 in one. Cleaned my rifle after every hunt then wiped the stock down with BLO, after 10 minutes or so I wiped off the excess.
I did refinish one badly scratched varnished stock using shards of glass (broke glass jars) as scrapers. It actually worked quite well, I then sanded, stained and applied several coats of BLO.
Philip Duffy
Bill, I have "chased" the checking on a number of gunstocks, for myself and friends. One tool - a straight line cutter - - of the correct size, ie 18lines/in will do nicely. But, all the finish needs to be done first and dried, then chasing takes place. Often you can restore work out or broken lines of checkering by just being a bit careful to extend the existing lines as a severe guide. I prefer working with a good magnification head set and outside in the sun where the lines jump off the "page". Phil
Barry Mabery
Ummm, Model 37. I love mine - a very used 20 ga. I keep looking in the few shops around here for a 12 ga, but only the occasional deer version seems to show up.
