Sanding for paint question?
I am making a table base out of poplar and decided to paint it black.
How thoroughly woudl you sand? Is it still important to sand with the grain? How fine woudl you sand?
My plan was to paint it black with black lacquer and then clear coat with satin lacquer.
(I am discovering that the first coat of paint has revealed defects worse than I thought.)
Re: Sanding for paint question?
It has to be better than if you clear coated
Dick Coers
Get a good primer as well. Have them tint the primer to at least dark gray. Sand to 220, then prime, sand 320 between coats, and keep adding primer till you don't see wood nor any imperfections. Then start the black lacquer. Sand with 320 or 400 between coats and before the clear coat. A high quality black lacquer isn't easy.
don stephan
My experience was that a black finish effectively was one grade higher sheen than the finish was labelled. Need darned near perfect surface.
Clint Searl
Clint Searl
When I do a base coat/clear coat finish I use a flat acrylic interior paint for the color coat, and top that with a one-part solvent acrylic lacquer in the desired sheen. The wood doesn't need to be sanded past 180; 120 would probably be enough. Check my "Gallery" for an example.
Fill before painting
You should have seen this recommendation the dozen other times I have posted it. Oil based Kilz, sand to be glass smooth with 180, paint. result looks like painted plastic. The Kilz is heavy bodied to fill pores and easily sands glass smooth. I have used something over 10 gallons of it for this application. It is best thinned a bit and sprayed.
Re: Fill before painting
I somehow knew I was screwing this up. I knew about the Kilz, because I have read your posts. I actually have some. Was reluctant to do it because the Kilz is so white. Thought about having it tinted, but from past experience I knew they couldn't do more than turn it grey. I visualized the table with a chip in the finish with the Kilz shinning through. Live and learn. Sometimes more than once.
(Used Kilz tinted grey to coat the entire inside of a house I flipped because it had an endless number of colors and sheens. It did a good job.)
Dave Bair
If you can get the April issue of PWW, there's an article on creating a charred and waxed finish that looks very interesting.
Would BIN work just as well?
Tim Greif - West of Chicago
Easy to sand is a key issue. Is KILZ easier to sand? Does if fill better?
Re: Would BIN work just as well?
Kilz is much heavier bodied than Bin. Bin Is basically shellac. Does and excellent job on some stains and odors but not all. (I tried to use it to cover the odor of dog pee in a house. Worked for a few minutes, but the pee had enough ammonia in it to pop through the Bin in the worst places.)
Kilz will sand nicely.
Resand between base and clear??
Clint, do you sand the flat color coat before spraying the clear? If so, to what grit? And by flat interior acrylic paint, are you meaning acrylic latex?
Clint Searl
Re: Resand between base and clear??
Clint Searl
Tim, as much as possible, I apply 2-3 coats the paint (Behr Premium Plus Ultra; I assume it's acrylic) with a foam or 4 1/2" roller to minimize brush-stroke-like ridges. Let it dry for a couple days. If sanding is needed, I use 220 drywall sanding screen. I top it with sprayed-on CAB acrylic solvent lacquer or brushed-on waterborne poly (Varathane) floor finish. Hope this helps.
Thanks, and no issues with lacquer?
My knowledge of lacquer goes back to car and bike painting. Back then, lacquer over anything was problematic because the lacquer was hot and would craze or wrinkle the finish of anything not lacquer based. You don't have any issues like that with the SW CAB lacquer?
Clint Searl
Re: Thanks, and no issues with lacquer?
Clint Searl
I've never had a problem with lacquer over waterbornes or oils, but let them dry/cure well before topping, starting with a light coat of lacquer.
