If you like Birch
Gary Smyth
Why not use birch ply and solid Birch for trim and rod holders? You might need less than you think. At least price out the solid Birch. In Western PA the price is about the same as Oak. It is heavy, much harder than pine and can splinter but the cost should not be too great and workability with tools is good (you may have to scrape burn marks though). Yes, stain can go on unevenly without pre treating. Dyed or undyed dewaxed shellac will apply easily, show grain, and get better with each coat. Test a scrap piece and see if it will work for you. Birch ply often has flame pattern. NOT my work, and not plywood, but Birch can look great, it is tough -- and it ages well.
Several coats of shellac for a test shouldn't take more the half a day. I'd apply finish before assembly even if you have to scrape some away to fit in mortises/rabbets for final glue up.
