Re: Thank you ....question
I agree, doing inlay and stringing doesn't put a lot of strain on a bench, but once woodworkers have figured out that these thngs reduce their back pain and increase the precision of their work, they start to use them for all sorts of other work. For example, Mary May and the cabinetmakers in the Hay shop at Colonial Williamsburg use them for carving, sometimes with a mallet, and sometimes by hand. Some people use them for laying out and sawing dovetails. In that light, some, myself included, attach a Moxon vise to the front of the bench. An advantage is that you don't need a separate Moxon vise, and you don't even need a purpose built rear jaw. It is also at a very convenient height for making moldings and trimming edge banding with a power router. Some of us use them in our shops but also take them on the road, for demonstrations in remote locations. If you need to clamp it to a picnic table or an F150 tailgate, or wheel it over a parking lot and a convention center floor, it needs to be a bit sturdier. In addition to all the uses I've mentioned above, I use mine all the time with holdfasts, which can put a lot of strain on the dog holes, the joints between the top and the legs and the ports used to clamp it to the substrate. When I'm working in my shop, mine is almost always attached to the top of my bench, so I don't have a need to find a permanent place to store it.
