3D CUTTING BOARD
3D CUTTING BOARD
Gordon Patnude
3D CUTTING BOARD
Gordon Patnude
I am in the process of making a 3D cutting board, as shown in the video at the YouTube link <<https://www.youtube.com/watch?v=sGcQVRZGzsY>>
I have watched the video at least 3x thru and until today, thought I understood the process fairly well.
Cutting all the diamond shapes turned out to be not quite as simple as the video shows. I have the DOUBLE DUBBY from In-Line Industries and used his example of cutting multiple segments for bowl, but by not flipping the stock after each cut, the result is a diamond not a wedge. My stop slipped during the process of cutting the diamonds and I had to create a jig to hold each small diamond and process each one a second time in order to get them all to be identical.
I am at the point where I have cut and glued the diamond shapes into hexagons and now I am facing the task of gluing the hexagons together to make the board, but I need some suggestions because, the wood, being imperfect, and me, being more-so, resulted in hexagons that are not perfect.
So, here is my plea for help:
I need a reasonably simple but sure approach to fitting all these &^%!** hexagons together without gaps.
I have glue and plenty of clamps and am not really in a panic to finish, but would like to complete this project in less than a century, preferably by mid-March. It is a gift for my daughter.
Any and all suggestions will be greatly appreciated!!
Re: 3D CUTTING BOARD
Dick Coers
Probably going to need an idea of how bad they are. Do you think they will have to be recut? That's the deal with segmenting, it has to be perfect. I have a fixture for making octagons for large wood threaded nuts, but it has a center locator in it that positions the octagons, and an angle locator fence. The parts have the hole for threading or the hole for the bolt shank to work from. You don't have a way to index off the center of the hex without putting a small hole in it. Do you have a disc sander? You might have to make something to locate them and then touch off on the disc.
don stephan
From the first few minutes of the video, looks like grain of the three pieces running in different directions. Why won't seasonal movement cause the cutting board to self destruct?
Jesper, Denmark
Re: My best guess........
Jesper, Denmark
Because the pieces are so small that the movement is also very small.
mdclor
Gordon, I made a glue board that is a piece of plywood and added stops to 2 adjacent sides that were perfectly square. The stops were glued and screwed in place, then everything was covered with packaging tape and waxed to prevent the glue from sticking to the glue board. Arrange your already glued hexagons against the 2 stops until you get the size/shape you are making, then use 2 loose stops cut to the appropriate length and clamp across from the fixed stops to the loose ones. You will need hold down cauls as well. Once you have done a dry run, you should be good to start the actual glue up. If you like, you can do the glue up in sections. Email me if you have questions. HTH
Also, as you know, any imperfections will be multiplied as you add more pieces.
kkruizen
Most of these type of cutting boards are endgrain otherwise it would be an issue.
Good luck these are very difficult. I have done a small one of these and I glued two of the colors together in a line with caul across the points . And after you have a few strip of zigzag together glue the third color in between the zigzags.
Sorry, way,way off topic.  Visual imprint
Gary Smyth
At any moment watching the cutting board video I expected space station to appear on screen. The music is forever etched in my mind with only one visual. In my view one of the best sequences in film ever done - models, blue screens and "new" servo motors.
This method seems easier *LINK*
terry quiram
Another method.
3D cutting board
Great movie!
Gordon Patnude
Re: This method seems easier -- really ???
Gordon Patnude
I don't know what you were trying to link to, but all that showed up on my screen was a promo for a new Disney movie.
Unfortunately, the Disney Company did not answer my question.
It worked for me.
Neal in San Jose
You may have to scroll down a bit.
Terry Quiram
I got the stupid Disney link as well. Try this.
https://www.youtube.com/watch?v=8P7YN56T1Gw
Slightly OT Does it make you dizzy?
Jesse Cloud
Very interesting project, but I wonder how good a cutting board it would be.
Personally, I get a little dizzy after looking at the thing for a while. Might cut a finger off. :\
Re: Slightly OT Does it make you dizzy?
mdclor
Jess, in my experience, most fancy designed CBs are only used for display. For example, neither of these has seem a sharp edge since leaving my shop.
