I can't find a design guide to the proportions of classic Tuscan columns. Similar to Doric, just no flutes. I've seen the placement of the entasis or bulge, 1/3 the total height from the bottom, but nothing to help design the curve of the column. Straighter on the bottom, to more curve to the top, or a constant curve over the entire column. Any help?
The person that can answer this question with authority is Alan Batty. Alan has studied this topic in detail and published a guide to column design. Where to find it, I don't know. He handed a copy out to those interested in our turning club. Maybe Alan put it up in the internet. One of the purveyors of turning supplies sells publications from Alan. Maybe they have it (I think it is the place in Utah).
Dick, I have a Chippendale Gentleman and Cabinet-Makers Directory here in my office/library, which has that all described. It takes a little adjusting to understand, since the f & s are interchanged.
I don't think legally that I can take a pic and post it online, but if you will drop me a personal email, I think I can share what you need.
But to try to answer the question, it does appear to curve more at the top. After you come up the column 1/3, then draw a semicircle of that diameter. Then mark off what appears to be 10º segments. The remaining 2/3 height above there, is divided into 4 equal parts. When you project up parallel to the center line of the column, where those 10º segments hit the semicircle arc, each in turn, will determine the diameter at that height.
That is tough to describe, and I'm sure even harder to follow if you aren't looking at a drawing.
There are several good reprints at Dover that describe all of the orders quite well. I'm pretty sure the Chippendale book does and there is another that I'm having trouble recalling right now....waiting for the coffee to kick in....
You're probably trying to recall "The Four Books of Architecture" by Andrea Palladio. Dover also has a reprint of that book. I would guess Chippendale got his column drawings from Palladio. They are very similar. I have both books in my library.
