Anyone Try using Guhdo/GMAXX Saw Blades?
Bart Goldberg
Bart Goldberg
While at the Woodworking show this past weekend, I saw a booth selling this german brand of blades that looked very well made called GMAXX. They had a coated blade with some very beefy carbide tips. Anyone have this blade and how was it compared to, say, Forrest blades?
Bart
Re: Anyone Try using Guhdo/GMAXX Saw Blades?
Blade comparison- by what metric
When one speaks of comparing blades it is essential to decide on what metrics are to be used in the comparison. If what is important is blade life then bigger better carbide equals more sharpenings and that blade wins. Other important metrics could be cost or how much it loads the saw motor which would depend on number of teeth and grind on the teeth.
In my opinion an over emphasized metric is smoothness of cut, cross cut and/or rip. In what I do saw cuts wind up hidden or further refined with the jointer or hand plane. Within reason I don't care how smooth the blade cuts.
There is a seldom recognized price to pay for smooth cuts in a combination blade. Forrest gets smooth cuts by grinding little relief on the teeth sides. As a result they load up with resins quicker and dull quicker. But on the occasions where one needs a smooth cut right off the saw they excel. I keep one on hand for these special occasions but it is not the blade I mostly use. For me a workhouse blade needs to be cheap to buy and cheap to own (how long it stays sharp and how many times I can sharpen it).
Good blades. Been around for a long time. Survivors in a tough industry. But they are primarily industrial blades. I don't see them in the retail trade, do you? If you can get them for a competitive price (say, re Freud or Ridge Carbide or Forrest), why not?
In general, I think you should choose a blade that cuts clean and stays sharp and has a grind that doesn't mangle your materials, which means the right tooth geometry. Forrest blades are excellent and their sharpening is also excellent, but Bill is right about side clearance. You pay for smooth cuts with friction and resin buildup. How often do you need a perfect surface off your table saw blade?
Bart Goldberg
Bart Goldberg
Bill and Ellis,
Appreciate both your detailed responses. I wasn't aware of some of the tradeoffs you both mentioned. For hardwood (versus plywood), I currently use a Freud dedicated ripping blade or a Ridge Carbide combo blade. Both have served me well. I was considering getting a dedicated cross cut blade, but not sure I need it as the Ridge Carbide blade does a decent job for cross cuts. When I'm milling lumber, I generally use my table saw for the last dimensioning step, so I like to get a smooth cut from my TS blade for that purpose. For this, I typically go with the "glue line" Freud ripping blade. I've never actually owned a Forrest blade, but am aware that most folks swear by their general purpose WWII blade.
Bart
David Yoho
I have had Forrest blades on my saws for many years. I use a 60-tooth on my radial arm saw that is mainly for breaking down stock to rough lengths. I keep a 40-tooth on the tablesaw unless ripping heavy stock, then I switch to their 30-tooth. Even with the cut the Woodworker II yields, for finished work I still cut a hair wider and clean the edge up at my jointer.
Seems to me if the technology is available
DizD
to get finish cuts off the saw, then you should take advantage of it. The traditional technique of cutting and then taking the piece to the jointer or shooting board to finish was an adaptation to the technology of the steel TS blade era. I'm currently using the Freud Fusion and GL rip blades and do most of my jointing on the TS ( I don't own a jointer.) The side clearance on the teeth is no problem if you keep it clean - I clean before every use and get the results I want without the extra steps. I still rough out material with other blades including the 7 1/4" but when I need smooth cuts I can get them. YMMV.
