Worked on my clock a little
Joe in a Cleveland suburb
I was able to work on the doors to my clock this weekend. I used scrap pine to test and practice making the, I guess it's called, bridle joints with offset shoulders. I did a bridle joint because I think it was easier than a regular mortise and tenon and I don't have a mortising chisel that would have been small enough. Didn't want to buy or making one either.
The doors turned out ok, but the cuts,joints, grooves, shoulders and so on aren't as crisp and clean as I would like.
Made sure things were square (doesn't seem to actually help - nothing ever seems to end up square). I double check sometimes with a square.
Squared up rails and stiles (or at least tried to)
Cut Dado's
Marked out shoulder cuts
Cut the tenons. You would think with a Freud SD508 I'd be able to get nice cuts. Never.
Cleaned things up a bit
Cut mortise
Stuck the rails and stiles together temporarily - looks like it might work
No. That's not the real clock dial...
Thanks for looking - if you see something wrong, tell me.
