Advice needed to make/match a hole
Gary
I am in the process of making a sewing machine cabinet for my better half. I'm really struggling with the recall part of my grey matter: I am at the point of cutting the hole for the sewing machine in the cabinet top, to place on the machine lift. The goal here is to have an opening cut out for the machine, and a filler piece of wood on the lift which matches the hole, so that when the machine is in the uppermost position, the filler completely fills the opening. I also need to (rabbit?) in a filler piece so that when the machine is in the middle position this piece fills the difference between the opening and the smaller space the machine takes in that position. Not sure if that makes sense to you reading it (can't read my mind, can you....).
What is the best way to accomplish this? Should I use a jig saw to make the rough opening, then route the final shape? I suppose that would be possible with an edge to rout against on the sides. How then would I make the filler piece the right shape/size? I really can't remember the steps here. Advise would be SO appreciated.
Thank you.
