General Machinery question
I am considering a quality mortise machine. General seems to be a recommended possibility. Where to buy and who will ship?
Re: General Machinery question
Bill Howatt
If it is a model that was General, as in made in Canada products, then you should be aware that they dropped manufacturing that line about a year or so ago. The products are now the off-shore manufactured General International line that had been carried concurrently with the made in Canada products for some time.
I don't know if there are models still at dealers but spare parts could be an issue but then again, that can be an issue with anything these days.
Bill
All the same...
John in NM
The new made machines are only differentiated by color of paint, whether General, Powermatic, Jet, whatever. Personally I don't care for them, but others seem satisfied. Main thing is a big enough motor and replacing the pneumatic piston as needed - like any other sealed gas piston they loose their pressure within a few years. Woodcraft sells them as well as Amazon and who knows how many other vendors.
There used to be another version of Chinese mortiser that I rather like (and found one of), but they are long gone. Bridgewood marketed those, they're long gone too. They had a big counter weight to help out lifting the head.
Stay far away from the Grizzly one with the big chrome wheel under the table. I found that one very fatiguing to use due to the huge spring used in place of the piston or counter weight.
Used ones are a different story. Any of the Canadian General machines are well worth the money in my experience. I've never used one of those mortisers though, just other Canadian machines.
TomD
I am pretty sure you aren't looking for the General Canada machine. It was like 4K and the weight of a VW bus, which is to say a good machine.
We see a lot of GI stuff up here, and the General one is OK, if you want one that does the angled joinery. It would be nice, but it really made the machine flimsy. I own two mortisers, both of which are really good. The first is an early Delta Desk top unit. I think it was the first one sold in the US. You can move it with one hand, but for what it is it is a tank. Made in England, and huge bronze gear. They sold for around 350 back in the back, I just mention it because you might see one. Downside is that after you buy it mortising (unbelievably) is still sorta a chore. And it isn't one you can tell yourself is good for you, like hand chopping them. When I buy a tool I want it to make that process fast and something I never need to think about. It should go to the back of the line as a process I don't dread.
So I bought machine number two. Classic form, like the General. You clamp the piece, the machine moves it, this is key because without that you spend all you time sweeping chips. Unfortunately, these machines were out about a year, and the angling ones came out, and those had that seeming versatility that sucks in punters (and might be worth it for chairs). But they are all flimsy. Then up here the sellery downgraded another step, and the machines aren't as good as some drill press set-ups. This is the general market, not GI.
This one off ebay is a good example of the second one I have While it is still basically a desk top machine, the column is about 8 times stiffer. There is a counterbalance weight, not a spring.
One thing I find is that I set up with a 1/4" and leave it in for everything. WIth a good machine, if you have say 4 large mortises to make and mostly make cabinets, or chair sized stuff, you set your preferred chisel up and just beaver away, the cuts are very clean, and you don't have to switch chisels, which isn't difficult, but neither is beavering, so it's a wash. So in that sense, the power capacity of my machine has never really been an issue.
Not all chineses machines, including those made in the same factory are the same. Importers have to decide what end of the market is theirs. High end suppliers have someone at the factory to ensure no bad parts slip in. And they try something new every shift it seems. These makers trade on their rep, and low returns. The makers don't usually make every part, they source stuff off the net too, and when it arrives they have no idea whether it is right for some guy's uses in Minnesota.
Re: Source for GI
TomD
YOu must have looked here?
http://www.amazon.com/General-International-Hollow-Chisel-Mortiser/dp/B003FWIT3U/ref=sr_1_22?s=hi&ie=UTF8&qid=1424207424&sr=1-22&keywords=mortising+machine
Jeff Heath
If I were you, I'd give strong consideration to buying an old American machine. They are not difficult to find, and are true beasts when it comes to getting the job done. Several manufacturer's back in the day made excellent quality machines. I've owned a few, including my present mortiser, which is an Oliver 91D. An excellent quality medium duty mortiser that has tilting table, 4" depth of plunge, with rack and pinion table movement, quality stops for setting up repetitive mortises, and a good clamp for locking down work.
I paid $700 for it, and all it needed was a good cleanup.
My previous mortiser is probably the finest ever made, by Greenlee of Rockford. It was the 227, which is a heavy duty unit with a 5 hp autofeed head with 6" of plunge, and handles, with ease, chisels up to 1 1/2" for hardwoods. Keep em' sharp, or they burn, because this machine can push rebar through dried concrete. I got this one at auction 4 years ago for $600, and made a huge error in selling it (thought I was moving, so I was thinning the herd, with about 35,000 lbs. of machines in the shop)
At present, I stay away from the pacific rim power tools offered for sale today. I've spent the past 10 years replacing one's I've had with higher quality machines that are "OWWM's" that perform as they should. The last asian machine in my shop is a 15" Jet planer from about 18 years ago, give or take. I have it's replacement, an 18" Yates American J180, waiting patiently for me to restore it. Once it's done, my shop will be completely purged of pacific rim tools, and I'll be a very happy guy.
Other quality machines to consider were made by Mattison & Crescent, and there are others, but I don't have any personal experience with any but these. I would tell you that if you find a Northfield mortiser, leave it right where it sits. Northfield makes great machines, but they laid an egg with their old mortiser, and took it out of production after a short run back in the 60's.
I'd buy one in a minute if I knew where to find one.
Jesse Cloud
If you are looking for a General Tools dealer, I highly recommend Eagle Tools in Los Angeles. I presume they will ship. The owner is extremely knowledge about tools and especially about the lines he carries.
Here's a link with contact info:
http://www.eagle-tools.com
If you are looking to spend serious $$, I would look for an 'old iron" horizontal mortiser, they produce much smoother mortises and can easily be jigged up for angles.
Bill Turpin in WNC mountains
Getting parts for General International is a human impossibility! I needed an electrical part for wife's midi lathe, that weighed about 6 oz. It was in stock in Canada, shipping was $50! It took 5 weeks to cross the border. I would not own any of their stuff if it was FREE!
That's better than Delta
Dick Coers
because at least you got a part. Delta doesn't have parts.
Jeff Heath
Bill
I might be able to help you with that. I'm a very active OWWM member, and am spending next week with about 50 of them working on machines and doing demo's next week, down in Georgia. If you want to email me your contact information, I can probably get you in touch with several options sometime in the next 30 days or so.....
Some of these machines will be meticulously restored, and some will be plug n' play originals. Just depends on what you're looking for. Some of these guys have serious "Arn's Disease" and have 4 or 5 machines in each category. One of my good buddie's has 20 table saws.....don't ask me why. He's an amazing craftsman, too, but can't stop collecting machines. These are the guys you want to talk to for prying one out of their sticky hands for pretty reasonable investment.
Let me know....you can email me direct at above address
I will help if I can.
TomD
I have been on the lookout for something like that for a long time. I love the castings that go to the floor, on any machine. Never had much luck, but they must be out there.
TomD
http://www.ebay.com/itm/Oliver-Vertical-Chisel-woodworking-Mortiser-tenoner-/350404093576?pt=LH_DefaultDomain_0&hash=item5195b62688
At a glance, the machinery for securing the wood does not appear to be included with this machine or the other one listed.
HC Sakman
Hi Bill,
I don't exactly know the answer to your question but I do have a benchtop tilting model and it has been working great for many years.
Chico
Ryan
Now you understand some of the issues we have north of the border - high cost of shipping (or not at all) from the US and longer wait times. Fortunately it doesn't happen a lot but it makes me think twice about ordering from companies in the USA
