Bill Tindall asked about making Legs
Alan Young
I am working on a pair of music stands.
Bill Tindall asked in Weekend Accomplishments how made the legs--here is the process--
This is the profile of the leg. I cut out six of these from a 2"+ thick board of Sapele
The "waste" is used by gluing it to the top of the board.
All the "not waste" pieces glued to the tops of the legs
The profile is placed back over the glued pieces and a final cutting is made.
Here are the results of the cutting/gluing and re-cutting
I didn't photograph this step but at some point I angled the table saw blade at 30 degrees and cut both end of each leg. this yielded parallel surfaces from the foot to the end that gets glued to the center triangle
I glued up triangles from baltic birch plywood where the three legs will meet and be joined with loose tenon joinery.
A jig is concocted to hold the legs for a pair of dado cuts
All the joinery has been cut- The grooves will be filled with loose tenons for the joint.
Each loose tenon is cut to size.
Cleats are screwed to each leg so there will be something for clamps to bare pressure against.
A two-part epoxy will be used to glue the assembly together.
The cleats screwed to the legs allow clamps to pull the structure together.
After the glue sets-(at least 24 hours) I start the process of refining the profile and surface of the structure- lots of hand filing and sanding,
This is what I have so far- I will return to these and continue to sand and file for final shaping. The pieces will all be stained/painted black to the contrasts of the plywood splines and sapele will meld together in the finish
