Spice Box Jewelry Box- applying shellac
Applying finish to drawers and case insides
The interior parts of the boxes are now finished. The drawer fronts were oiled and then finished with garnet shellac. The case insides were finished with Zinsser shellac, which is not nearly as dark as garnet shellac but it is vastly cheaper and doesn’t “go bad”. Garnet shellac looks nice on walnut. My 10 year old Garnet Shellac has polymerized and is largely no longer soluble ( see Discussions on Hand Tool Forum about this problem). I got enough dissolved to seal the fronts. When I get some more I will add another coat to the fronts.
The shellac was brushed on with a foam brush. Some foam brushes disintegrate in shellac. Those from Woodworker Supply that come in packages of 50 swell some but otherwise stay together. The foam spreads the shellac well. For interior furniture parts I brush on full strength Zinsser shellac (Zinsser because it is cheap and stable. A gallon of 3 pound cut is less than $50). I then sand smooth and recoat with diluted Zinsser just thick enough to restore the gloss after sanding.
On something like a chest of drawers I normally finish the case inside and the insides and sides of drawers. Shellaced drawers look and feel better and stay looking better than unfinished drawers. Shellaced case sides are resistant to moisture changes and hence stabilize case sides. The hard shellac provides a low friction surface for the drawer sides to slide against.
I did two things that I would not do again. I lost concentration and began finishing the bottoms of the drawers. There is no need to finish the drawer bottoms. Normally I would just wax them. The problem with finishing bottoms is one is not left with any surface to sit them to dry. As a result the drawers must be finished in two steps, a great waste of time. Note the “parts everywhere” problem
I made the decision to finish the drawer partitions. Because of the cramped space this finishing must be done before assembly. The result was a lot of effort for no benefit, I think. I wish I had assembled the case and then just finished the outer 1” or so of the dividers and waxed the reminder.
Next step is door frame assembly. I am trying a new coped frame joint and will report its success, or not. It is not going easily so far.
