Finishing
David Frame
Hello All,
Does anyone out there finish their woodwork before it is assembled? I'm mainly referring to the interior of cabinets and the like.
Thanks
Finishing
David Frame
Hello All,
Thanks
BTDT
But I don't do much interior finishing on cabs beyond a coat of shellac to control dust in the interior. As I make the carcase out of ply, I tape off the glue joint areas and the mist on a coat of 2 lb. cut the shellac with the box saides laid out flat. I then peel the tape while the shellac is dry but still soft. Makes removal of glue-squeeze a simple wipe with damp cloth with no glue staining. If doing M&T joints, I wrap the tenons with tape and stuff the mortices with some paper to protect the glue surfaces.
Outside finishing can usually wait until after assembly.
Re: Finishing
stay tuned for Spice box update for answer and details
OTOH
When doing AV cabs, I prefer to turn the interior into a "negative space" to allow the components to float in a void. Thus the interior is finished in several coats of flat black paint
and then those ares are masked when the piece is put together and finished
