Shop Lighting Upgrade - Addendum *LINK*
William Duffield
A few days ago on another thread on this forum (see link) I posted a description with pictures of how I reused old T12 fluorescent light fixtures to upgrade my shop lighting.
On the way to making it into an article, I realized I could now offer some suggestions that make the process even clearer, easier and less expensive.
Some actual measurements of the locations of the drilled holes might save a little time. A standard 4 foot fluorescent lighting fixture is 48" long. Duh! I centered the first hole 6-1/2" from one end, and spaced the six holes 7" apart down the center of the fixture. If you are going to convert more than one fixture, you might want to make a story stick from the first one, or at least set up two pairs of dividers.
I suggested epoxy to attach the sockets to the fixtures instead of the hot melt glue I used. You would have plenty of time to use 5-minute epoxy. Construction adhesive or bathtub caulk would also work.
In the fixture in the first photo, I mixed and matched bulbs of two different colors. It's easy to experiment to get the color you want. The other photo showing a lit fixture is currently using five CFLs and one LED.
I just found out that Harbor Freight now carries larger sizes of the Titanium Nitride coated step drills, that will make holes up to 1-3/8" diameter, so you don't need the knock metal kit. This method is a lot quicker, and when they're on sale, as they are now, even less expensive than the punch set. I wish I'd known this yesterday, while I was going right past a Harbor Freight.
http://www.harborfreight.com/2-piece-titanium-nitride-coated-high-speed-steel-step-drills-96275.html
CheapShop Lighting Upgrade
