Bed measurement question
Jim in N. Va
I'm about to build my 4th bed, but this will be a little different from the first three and I have two design/measurement questions.
The mattress will rest on a closely spaced slats between the rails. How far down below the top of the rails would you have the top of the slats? That is, how far down would you inset the mattress?
I'm thinking something like 1 inch. Enough to prevent the mattress from moving side to side, but not so deep as to make it hard to tuck in sheets and blankets.
Second question...how much larger would you have the dimensions between the rails relative to the mattress size? For example, if the mattress is 55 inches wide, would you have the space beween the rails be 56 inches? Again, I figure you need a little space to tuck in blankets and sheets but not so much that the mattress moves around.
Hope this is clear enough! Thanks for your thoughts.
Jim
Re: Bed measurement question
Tom Dunlap
Fwiw
My mattress...no box spring... Is foam. It's been on. A plywood deck with no lip around the edge for many years. I do have an edge piece at he foot because the pillows I prop behind me act like wedges and scooch the mattress away from the wall...no headboard (that's my next project).
The plywood deck is the same dimensions as the queen size mattress. Again, no lips on the side.
You could take a scouting expedition to IKEA or a furniture store and see what is typical
Tom
Hoa in Alameda
I have 2 beds similar to your project. The "depth" is about 2" and the width is 1" greater than that of the mattress. That works fine for me.
Personal preferences
My personal preference is to use a box spring under my mattress, which pretty much changes everything. In that case, I set the slats as low as possible on the rails so the foundation will nestle down in there. We put a ruffle or something over the foundation and under the mattress and tuck the sheets in between mattress and foundation.
In your case, you have a couple engineering issues as well as spacing issues. If the slats are providing all the support for your mattress, they need to be beefy enough that they won't tend to bounce or sag, or else you'll find yourself rolling to the center of the mattress. An inch of additional width and length to the mattress opening is pretty standard, from what I've seen and done over the years. It's a good idea to work from standard mattress sizes, though. If you size a double bed for a 55" wide mattress (a standard double is 54" wide), your bed frame is going to be overly wide for the replacement ten years from now or whenever.
Sgian Dubh
The bed in the photo below uses an 80" X 60" mattress. The top of the slats are set 2-1/4" down from the top edge of the rails. Space between rails is 61-1/2". Distance from headboard to footboard is 85". However at the footboard end there's a 1-3/4" tall upstand attached to a slat with its headboard facing face set 4" away from the footboard. Therefore, headboard to upstand is 81". The upstand holds the mattress tight to the headboard and provides a 4" gap for bedding to down tuck into, useful if bedding includes a heavy and thick downy. Without a footboard there would really be no need for such a gap, but it works well in this situation. These dimensions hold the mattress in place and make it easy to make the bed, changing sheets and the like.
The slats themselves are 1" thick poplar. They're stapled to two strips of hessian (burlap) and the end slats hook over a retainer and this arrangement keeps them evenly spaced (and the slats are simply rolled up if the bed has to be moved, and because they're all attached to each other you don't lose any of them!). There's also central longwise running bearer 1-1/2" thick for additional support. This is more than adequate to carry the load of two adult sleepers of normal size and weight. Slainte.
Jim in N. Va
Thanks everyone for the helpful advice. Ellis, maybe I've only every seen "cheap" box springs, but all the ones I've seen have primarily been glorified fabric covered boxes. I always think they are a rip off, but again, maybe I've just not seen nice box springs. In any case, I do not want to have to add a dust ruffle to hid the bottom of the box spring if it extends below the rails and do not want the height that it would add if I raise it up.
Sgian, thanks for the photos and the measurements. (Really beautiful bed, BTW.) The burlap is a great idea that I may borrow. I may also add the center support, or I may stiffen each of the individual slats with a strip glued and screwed underneath (So that in cross section each of the slats looks like a "T".)
Jim
