200+ woodworking book reviews
Planning a Shop - Where do you start?
Ray Carson - Lawrenceville, NJ
Whether you're a first time woodworker or a seasoned veteran, there comes a point and time when all of us have thought about laying out a woodworking shop. A place for everything, everything in its place.
The novice woodworker starts collecting tools and machinery and wants a plan. The veteran wood worker might have a space in the garage, basement or freestanding building and has acquired additional tools and wants to reorganize the layout of the shop for better efficiency. So, how do you go about doing it?
This can be a daunting task if you’re trying to imagine the work area needed and also if you’re trying to move your heavy equipment around trying to find the best location. Take my basement shop for example. I have two pipe columns that are in the perfect WRONG spot. I’d love to take them out but for obvious reasons they need to stay. I have to plan some of my projects around these when I’m cutting sheet goods. Then I need to plan an assembly area that won’t interfere with the rest of the construction.
I made a recent post on Wood Central asking if anyone had CAD files (.dwg or .dxf format) to aid in the layout of a shop plan for a friend. He’s building a standalone building on his property and he’s trying to plan on his current machinery and future expansion. I’m a draftsperson by trade, easy peesy.
I was very fortunate to get the files I needed from fellow Architects and right here on Wood Central. Thanks to Tony Haukap and Tony – Memphis for the help.
Don Orr wrote on the post I made, “This forum is amazing” “Just look at what we have been given access to from someone asking a question!” I agree. Now everyone knows that we just don’t go around rearranging our shops every week. However, wouldn’t it be great to have a central source to get everything you need without spending hours researching and downloading files?
So, I contacted our fearless leader (Ellis) and he suggested opening it up for discussion here on the board.
Questions:
1. Would it be a benefit to have an archive on Wood Central of drawing files showing woodworking machines, their work area, etc. to aid in creating a shop layout?
2. What file format or program would you most likely use? AutoCad, AutoCadLT, TurboCAD, DeltaCAD Sketchup, “BlueBeam” (an Adobe like program only better) Adobe PDF are just a few.
My post,
Subject: CAD Drawings of Woodworking Machines
Posted By: Ray Carson - Lawrenceville, NJ
Date: 1/28/2015, 10:02 am
Re: Planning a Shop - Where do you start?
Re: Where do you start?
It may sound strange but I'd start at the door. Getting material ( and tools) in or out of the shop has a direct effect on work-flow support for the various methods that will be used to render that material into a finished piece of work.
So, take the gross measurements of the available space and plan the door(s) and access based upon the hypothetical path that a board will follow. I've seen shops organized with a circular flow as well as ones in an "L" or "U" configuration.
For instance, if you work with sheet goods, you may want to locate a panel saw or other break-down tool near the entrance so you're not humping 4x8's all over the place bumping into (or knocking over) other tools. Next in line might be a chop saw or RAS to set lengths. If the entrance is a garage-type door, does it need to be full width or can a 4' roll-up do just as well?
In this sense, most every shop will reflect the person who works in it and has a particular method that he/she prefers to follow.
Hmm, some thoughts on the process and... *LINK*
Grant in Iowa
I think woodworkers who stay put in their shop kind of "let the tools decide where they want to live on their own". By that I mean that the needs of various projects eventually necessitate moving things around, and therefore the machines, benches, etc. sort out their best locations organically.
Perhaps the best time for a woodworker to create a plan is when they have a new space to move in to, whether it be another space at the existing domicile, or a new home entirely. This is where the tool icons would be most valuable.
I think any such tool icon should:
-come in sizes just like in real life (lunchbox planer, 12" floor planer, 15" floor planer, woodmaster 25" planer, etc.)
-Each tool should have infeed/ outfeed space in some reasonable form.
-Be available in several formats (suggest .dwf, pdf, jpg, maybe more) It should be simple and quick enough once a .dwf version is created to export in to several formats so the most users can benefit.
-Items should be to scale, and the scale stated in the download section. In this way, the user can know what scale to make their drawing. A drawing that is not to scale is not very valuable.
-Some items that should be included that are often not are lumber racks (various types), dust collectors, ducting pieces and drops, trash cans, benches, tables, overhead doors, doors, windows, vises, benchtop tools, etc.
-Since such a list of drawings will likely continue to evolve, it might make sense to have the ability to upload drawings too. In this way, it could be the Wiki of tool drawings.
Rapidly becoming the de facto standard due to its free cost, Google Sketchup would perhaps be a great format to get started in. Straight to 3d. These drawings can then have a snapshot made of their top down view for those who don't need 3d. Draw it once and be done. So maybe .skp file would be the starting point for your project, and other formats are exported from there for simplicity. There is also a decent library of .skp machines. Since they are open source, just search on them and download a starter group of machines.
Thanks for taking on such a project. It would be extremely useful. You might be able to garner some assistance from other WC members who could help with creating drawings and converting file types if it all becomes too much.
FWIW,
Grant in Iowa
Google sketchup woodworking tools
Re: Hmm, some thoughts on the process and...
Joseph Mulherin, sr
I too am planning on redoing my shop. Years(eons) ago I made a system of drawers and kitchen counter on one side and on the other side i left room for my Shopsmith to roll away and the car could enter the space too. But, now i have the Shopsmith, an elevating workbench, bandsaw, another table saw, and another drawer assembly on wheels i can roll to the other wall.
On the original there were four drawers in four sections which I have measured and am thinking I will saw off two drawers from each section leaving me room for my plastic buckets of tools, cords, and whatever.
I am thinking the stiles would hold the upper two drawers because they are screwed into the upper frame, and if necessary I could brace up the lower sections with some angle iron to maintain stability.
If things do not work out and all falls down....so what....I am remaking it anyway.LOL
Got to have something to do in my retirement before i go crazy. Want to get back to making some rocking chairs like the ones from Hal Taylor....rockingchairuniversity.net
One of the things the tool drawings need to show is the infeed and outfeed dimensions. For example, I have a very small shop, a single car garage, and my table saw faces the overhead door and the blade is 16"+ and inch or two from the back wall. Its about five feet from the door. If I need to rip a long board I open the door and let it feed out into the driveway.
I have my shaper, chop saw, and RAS lined up along one wall. The fences line up and all the tables are at the same height. The jointer is turned at about ninety degrees to them and the top of its fence is the same as table height on the others.
My lunch box planer top is at the height of the BS table and is on wheels so it can be an out feed table. And the table on the planer is below the wing on the TS so if I have too I can feed a 16' board through it and out the door.
The point is the shop is more three dimensional than it might appear, so being able to "view" it in elevation as well as plan view might be useful.
There is a four tube fluorescent fixture above the TS. When the garage door is up, the window in the door lines up with the fixture and it still illuminates the saw. My son thinks I was lucky. NOT
Another thing. I have seen a couple of wonderful shops that were missing one thing. A place for the protect. You gots to leave a place to build something. Maybe the tool files should have a hunk of space.
Keith Newton
Maybe you should get started trying to work it out, then post it here to ask for suggestions. There should be plenty of experience to spot things, and offer other suggestions.
You've gotten some good advice already about planning material flow, and planning infeed and outfeed room. Let me just add, that just lining the tools up in a row, is a horrible waste of space for a small shop. Think of doing groupings of tools with their backs together. Threes work well in triangles, because in and out paths cross and are shared not only within the group, but then on over to other surrounding groups, leaving large areas in between to bring up projects. Play with this, and you'll see what I mean.
William Duffield
Put as many machines as possible on rollers, but not the drill press. It needs to be bolted to the floor or to a large steel plate, so it can't tip over. To make those steel posts as unobtrusive as possible, you may be able to put one directly behind the drill press post, and the other behind (to the left of) the bandsaw post. Those areas are not used for moving materials when you are using those machines.
When I finally was financially able to finally build a shop, I went into the back yard and laid out the area I could use without removing trees! I found I could build a 30' X 30' shop. I decided to install a high garage door to enable me to both install heavy machinery and move materials and projects in and out without a hassle. I then decided to install a LOT of outlets, both 120 and 240 volt. I installed a 120 outlet 4' high on every other stud in the shop, switched outlets in rows across the ceiling + 5 incandescent fixtures, 240v outlets (I believe I installed 8 or 9) in various positions on the walls.
At the time I believe Grizzly had a machine outline for almost all basic machines, so I printed them out and made a to scale sketch to layout the basic machinery positions. Then I purchased my machines and installed mobile bases on almost all. The only "fixed" machines in my shop are the 60 gal air compressor, my Surface grinder, and my Powermatic lathe. I installed my 3 hp cyclone dust collection system on a wall and installed 6" pipe across the ceiling with multiple drops at various locations, using flex tubing to do the final connections.
As my shop is occasionally used for repairing automobiles (by my sons) as well as other projects the mobile equipment is really handy. I can also join and plane just about any length board by moving the equipment to feed the board out the entrance or garage door.
Paul Blackwell
Go to www.grizzly.com, scroll down to the bottom of the home page and find Shop Planner. This allows you to set up a floor plan to your shop dimensions and there are icons to scale for all woodworking machines. For example, under Planers, there are icons for lunch box planers up to large industrial size planers. Might be worth a look.
Planning a Shop - Feedback
Thanks to everyone who posted. Feedback on the subject was the first and main goal to see if there is a demand for such an archive. Secondly, to tap into the knowledge and input of everyone on the Wood Central forum(s). I know my post was a little winded but I think Grant saw best exactly what I was going for.
I agree 100% that a huge part of laying out a shop is knowing and understanding the spacial requirements of the individual machines. This is why I pitched the idea to Ellis and to all of you.
If you have a very small shop then machines must be mobile. You are forced to maximize the usable area. Take a table saw, the staple of almost every shop. It requires an exceptional amount of room, especially if your cutting sheet goods.
This "Wood-O-Pedia" of machine drawing files would be an archive for the masses, not just for me. One central source or library that a person could access that would host a variety of formats like those mentioned. I believe Sketch Up is by far the most user friendly for a novice "drafts person" and yes, it's free. However, not everyone uses a computer or may want to go through the hassle of using a computer. Maybe they just want to print out the plan views of machines (to scale) and layout a shop out old school. Simple graph paper is fine for some. Wouldn't it be wonderful to have PDFs to print and cut out and lay on the paper to facilitate the process? I've used the online Grizzly shop planner but I find it a bit cumbersome. My background is in AutoCAD and Revit so I just find those drawing formats easier to deal with. Just my two cents worth.
Wouldn't it be great if a Google search for example listed Wood Central as one of the top resources for an archive of this information.
Some ideas sound great but they're just that. I think this has potential.
Ray
"I'm an idea man Chuck" "Feed tuna mayonnaise" - NightShift
David Hay
A few random thoughts about shop layout, having just gone through this over the past couple of years. I built a 20x24 building and set up my shop shortly after moving into our current home.
I spent a fair amount of time deciding on a building size, location of electrical, windows, doors, etc. I also spent some time thinking about the layout of machines, benches, etc., as that affects where the previously mentioned items go.
However, in the end, I found that two-dimensional drawings (I used Visio) only get me so far. Actually standing in the space and seeing how the machines and benches relate to one another is far more effective for me. Don't get me wrong, I think that seeing other shop layouts as inspiration is a good place to start. But actually being able to move the machines and benches around is very useful. While some things have been stationary from the start (a massive bench where my CMS lives), I've moved just about every other piece of machinery and bench from their originally planned locations. The mobile clamp rack I made when I first set up shop has lived in three distinct locations in about as many years!
Some things to think about:
* What machines do you use most often?
* What tools and machines do you typically use together or in rapid sequence? (e.g. planer/joiner/table saw or band saw/lathe)
* Where does material live? How does it enter the shop? How does it flow through the shop, based on the type of work you do?
* How do finished projects live?
* Are the materials and tools used during each step of a project located near the space you use them? For example, are clamps located near where you assemble things? Are finishing supplies near the bench where you apply the finishes?
* To what extent can you make things mobile?
* Are things like hand tools stored such that you can bring the tools to your work (e.g. a box with your chisels, carving tools, marking tools, etc.)
Hope that helps!
Oh well ...
