Drawer construction material question
Pat Evans
The drawers in our recently purchased MH are falling apart. The fronts, bottoms, and slides are fine. In fact, the slides are heavy duty, full extension. However, the sides and ends of the drawer box are some kind of vinyl wrapped MDF I think. The sides are merely stapled to the ends of the front and back of the box. They are coming apart badly. The previous owner attempted to put in screws instead of staples and only succeeded in splitting the fronts and making things worse.
What would be the best material for the drawer box? I've got plenty of pine, but would poplar or plywood or something else be better?
Re: Drawer construction material question
David Yoho
I'll assume MH = motor home. Rebuilding new drawer boxes is the way to go and I think your pine would work just fine. Poplar would also be a good choice because it's lightweight and that's important in a MH. However, since you say you have plenty of pine, why not use it. The slides do all the work. You just need to construct boxes that will last longer than those cheap things they used.
What is a MH?
Depending on what an MH is any of the choices you listed could be fine. Our kitchen drawer boxes were made of poplar and they have held screws for the Accuride slides well.
MH = Motorhome
BrianMonumentCO
Baltic birch plywood with machine cut half blind dovetails.
I once found a store on line that provided draw parts pre cut.
Thought it might be rockler or woodcraft.
I don't remember what the material was.
Thanks for the responses
Pat Evans
Time constraints mandate that I go with the pine I already have. I'll just mill it down a little, slap some paint on it, and cut/dovetail the pieces.
Re: Thanks for the responses
Lee Schierer in McKean, PA
Materials used in motor homes and travel trailers tend to be pretty cheap materials despite the purchase price for the motor home or travel trailer. 1/2" poplar makes excellent drawer sides that will last a lifetime, without adding excessive weight. Just be sure to use lock miter joints or dovetails for the corners.
Lee
Re: What Kind of Pine?
Hank Knight
Pat,
What kind of pine do you have? Clear, dry white pine or sugar pine would make fine drawer boxes. Old growth southern yellow pine has tight, straight grain and would work well also, but it would need to be dry. Most southern yellow pine cut nowadays and generally available is construction grade and would be a poor choice for drawer boxes. It is almost always wet, coarse grained, hard to work and prone to warping.
My $.02.
Hank
Re: Thanks for... plywood.
TomD
That will probably work nicely. One reason motor homes, use composites, along with saving money is that it depends how controllable the internal environment is. If it get extremely hot, as it might when stored in some parts of the country, real wood may not make it. Something like baltic birch or exterior grade "marine plywood", is great and can cost less than pine (if you don't start with either). Both dovetail nicely. And joined with epoxy are environmentally stable.
I have a local store that sells "marine ply" for 30 dollars a sheet, it is finish sanded, nearly, and the yield for drawers would be nearly 100% while starting with lumber it can be 50%.
