I'm making a very small table for my foyer. Probably 12" by about 30". I live in a bi-level house so the foyer is actually the stair landing. Not much room but I need a small table there. I'm inclines to make it about 30" tall, but was wondering if a little shorter might be better? Just for fun I am thinking of cabriole type legs, so I can't cut them off later. Any thoughts?
Thirty inches is just fine, it, is pretty much a standard for dining height tables which are also seen down to about 28". But since you are not likely to be using this for dining, you can do it any height you want. I would imagine that if you make it too tall it would be difficult to make the cabriole legs have a graceful curve without making them project a lot into your landing.
I am not using ball in claw feet. Way to much of a utility table for that. Not even sure if the legs I anticipate are actually cabriole. Mine will have no foot or a slipper foot.
OTOH, I can visualize any leg you want on yours. Just requires a little imagination to see them.
Build a mockup, not only to get the height right, but also to make sure you can easily navigate around the top. For height, I would start at the bottom of your elbow with your arm hanging down and your elbow bent at 90°.
Cabriolet legs don't protrude into the room any farther than the edges of the apron, so you shouldn't have any problem with tripping over them.
…the part about starting at the height of your elbow, that is. That height is for working up close with your hands on detailed crafts (ref. Steve Latta's bench-on-bench). A better place to start is at kitchen counter height, because, like a counter top, you will probably be using the hall table while standing, and will be setting objects down on it and picking items up off of it but won't be sitting at it.
Hey, Bill Tindall hit it right on -- 36"!
Curiously, when you take a survey of specs for console tables, sofa tables, etc., the maximum height is about 30". That doesn't make ergonomic sense to me for their intended use. Maybe shorter tables look better in the showrooms, or they're cheaper to manufacture?
This is interesting. Somewhere along the way I studied ergonomics. It had to do with buildings, not so much furniture, but built-ins. At that time they considered the height of kitchen cabinets (36") to be too tall for most women. If women were the users of the kitchen, 30" would have been better. Assuming women were about 62" to 66" tall. If they were to stand at a table and mix something in a bowl, as in using a spoon or a whip, it would have been much more comfortable if the table were 30". At 36" they would have to bunch their shoulders and hold the spoon up higher than comfortable. It was assumed kitchens had been designed by men without considering the height difference. At 68" tall, I find cabinets to be too tall, but I am stuck with it because of the appliances. I remember installing a modern kitchen in my grandmother's home. It was an eat-in kitchen and she did nearly everything on the table, probably instinctively gravitating to the more comfortable surface.
1. It really doesn't matter that much. A wide range of heights will work. Just scale the cabriole shape to your design. Draw it out full size and fool with the drawing until it looks right.
2. If this is for your own use, then plan it to fit your body. We have an entrance hallway table thats a waiting place for mail, keys, etc. Its top is a little higher than where my wife's fingers are when she's standing up.
And, its perfectly ok to adjust the height a little to best use the wood you have!
The height even depends to a certain extent on the height of the objects you are going to manipulate on the table. Luckily, our shoulders and our elbows are flexible in several directions.
When I set up my bench-on-bench, figured I would be working on relatively narrow table legs, sometimes on top and sometimes in the vise. If I were using it for carving, as Mary May demonstrates in some of her videos, I might want it lower. But, the most important consideration is to let your wife make the final decision, using the height of the mock-up.
As an example, here's a tea table with lines and proportions I kind of like. Sorry about the cluttered background.
When you find one you like, and want to make a pattern of the leg, make sure you get a photo from this direction to work from. If you were to use the first photo, the legs would end up too fat, especially if the original's legs are rather square in cross section, and if it has slipper feet, they'll end up about 40% too long.
