Saw Stop, is in the house
TomD
Not mine.
I was at the Lee Valley store in Scarborough, and they had a cluster of Saw Stop saws on the floor. The saws were adorned with a big sign requesting that people not touch the (guarded) blades as they are sharp and could cut. I guess it takes a Saw Stop customer (obviously any present company excluded)... It makes one think that possibly they need a contraption that ballistically withdraws a blade when the saw is not running, but in case a person reaches out to touch the unturning blade. You can't be too safe...
Re: Saw Stop, is in the house
CJ in MPLS
The sign is a rhetorical tool to be used to establish a superior position over an embarrassed shopper who reacts with indignity and not a legal one.
I'd bet 90% of those customers
Gary Smyth
try to sneak a touch on the blade just to find out if the blade drops. I wish some engineer could design a way to rig up a tape that, when the blade on the display is touched, would loudly beep a horn and announce twice "I advised you not to touch the blade. You are a menace in the shop. Please step away".
That'll draw unwanted attention to them and before they slink away make them think again before disregarding safety instructions.
William Duffield
Yes, and we should require the safety mechanism on chisels, turning and carving gouges and dovetail saws too. And, after that they will want it on hammers and screwdrivers.
For those who are curious, After power has been turned off and the blade is spinning down, if you touch the blade, the brake will activate, immediately stopping the blade. Whether the blade will retract below the table top depends on how much kinetic energy remains in the blade, arbor, pulleys, belts and motor windings. Then, you replace the brake. You might be able to get away with not replacing the blade.
After the blade has come to a complete stop, the brake is deactivated.
The place I used to work sells SawStops to high school industrial arts programs. One shop teacher was introducing the SawStop to a new class of students, explaining how it worked and how to operate it. One of the students decided to try it out, and intentionally put his hand into the spinning blade. I'm not quite sure how to summarize the lessons learned from that incident. Hopefully, he didn't try the same experiment on a radial arm saw, chop saw, band saw, lathe, etc. with which the classroom was also equipped.
Re: I'd bet 90% of those customers
William Duffield
Why would you do that? When you apply power to the saw (not to the blade) it runs a set of diagnostics, and shows the results in indicator lights. If you get some soggy PTSYP from the Borg, to make sure it won't trip the brake, you simply touch the wood to the side of the blade (or better yet to one of the teeth, if the blade is teflon coated). If the wood is too wet and would have tripped the brake, an indicator lights up, so you know not to try to cut the piece of wood. It works on a finger or hot dog too. BTW, the saws and other power tools out on the display floor aren't connected to power, and the ones in the classroom are unplugged when not in use.
Alex Grigoriev
I suppose that student was kicked out of class immediately.
I don't know, but I hope not. I hope the teacher modified the lesson for next time, stressing earlier in the lecture the expense of the brake and blade and how it can sometimes be difficult and time consuming to get them off the saw. Usually they come off easily, but sometimes the blade takes a crooked bite into the brake shoe, and the brake pin and the hole in the center of the blade get misaligned and don't slide easily out of the saw.
You can make a really neat shop clock out of a blade and brake.
