ADVERTISE HERE - FREE TRIAL
OT-Fiberglass door repair
mdclor
We live in NM above 7000' and the sun gets pretty hot here. So much so that it seems to have melted the adhesive that holds the fiberglass trim to the door on our SE facing deck. I tried using 5 minute epoxy to re-glue the moldings back into place and it worked for a while, but the sun won. I can't be the only person with this problem, so what have others successfully done to fix this?
Re: OT-Fiberglass door repair
Terry in Edmonton
Maybe change to a steel door? If the factory glue failed I doubt you will find anything that will do a better job. Up here in the great white north our problem is cold. It seems that any fiberglass door that survives has very poor insulation.
mdclor
Thanks, Terry. Unfortunately, one side of the door is fixed so I would have to replace the entire door frame and casing which would mean messing with the stucco on the outside and the dry wall on the inside. That is more than I want to attack at this time. :\
John in NM
I can't tell from the pics, looks like molding around a window in the door?
I'd offer to stop in and have a look today, but I may have to bail on lunch anyway (just sent you and Jess and email). Cow jumped over the moon and I have to go find her :D
Do you have a storm door? All the doors I have seen like this say a storm door voids the warranty, somewhere down int he fine print. It r\turns the door into a solar heat collector and the space between the door and storm can get very hot, so hot you can't hold your hand on the knob.
If this is a south facing door it can get hot anyway, what with the reflected light off the deck. The combination of UV and heat are tough on epoxy or any other glue.
I'd try polyurethane sealant
High heat JB weld.  stands up to 450 degrees
Jason Roehl in Lafayette, IN
I like this suggestion.
While the door may be fiberglass, I'd bet dollars to doughnuts that the cracked trim piece you have pictured is plastic (vinyl).
I think the polyurethane caulk/sealant is a good idea, but I think any non-silicone exterior caulk might just do the job. They will give the trim some ability to move relative to the glass as the glass and plastic will expand and contract at different rates in the heating/cooling cycles the sun causes. I suspect any substance that hardens will fail in short order.
Jason
Re: Trim repair
Around here, the fireplace guys use 100% silicone caulk to mount and seal fireplace hardware and inserts to the masonry, including inside the fireplace so long as the joint will stay out of direct flame. The good stuff will "supposedly" take up to 500°F before it degrades.
Betcha clear silicone would fix you up just fine. Epoxies will soften and fail above 150° so not surprised your sun won.
mdclor
Barry, no storm door, this is NM and we don't get any real storms here. :D
mdclor
Thanks for all the replies. I will pick up a couple options and test each one in different locations. :)
PS
Keep in mind that at 7,000' your real enemy is increased UV. While you may find stuff that will take the heat, your best defense will be to block the direct UV light.
Up for building a "veranda"? :D
mdclor
There is Loctite PL S40 Polyurethane Window Door and Siding Sealant that is UV resistant and rated to 200*F. I hope that will be adequate.
Great stuff...
Tony-Memphis
I found a line of adhesives/sealants at Lowes and HD called PL. Their black roofing caulk is amazing! I've used it to seal nail holes in the roof left by the painters where the silicone they used fell out. It stays fhard but flexible in the sun for many years...so far. I even used it to repair the convertible top on our Z. It was in an area where the fabric had lots of tension on it. I was really jus trying to keep the weather out until the top was replaced, but that stuff held for a long time and many cycles. I keep a tube around and use it for all sorts of stuff. There are other types in their line, so maybe they have something that might work for this application? I think Tightbond or somebody else owns the product line?
Tony
Re:I would try Automotive trim adhesive
A lot of the exterior trim is affixed to the newer model cars using nothing but adhesive. All of the adhesives used have to withstand the very conditions you are fighting. They are heat resistant, water and sunlight resistant etc. and work quite well. I searched and found this one but you might want to talk to local body shop personnel to see what they find works best! http://www.autozone.com/sealants-glues-adhesives-and-tape/body-trim-adhesive/3m-tube-plastic-emblem-and-trim-adhesive/316901_0_0/
mdclor
Thanks, Larry. I am going with silicone on one and the polyurethane sealant on the other for now. If they both fail, I will try this.
