Cutting 2" Cherry with old Tools
Bob S
Hi,
I bought 10/4 cherry, and planed down to 2" and put one good edge on, using my planer/jointer.
Now, I need to cut into blanks for the lathe (2" x 2" x 30" ).
My table saw is very old and my moderate/high quality 80T finish cut blade is pretty sharp. It is able rip the edge off the slab, but works hard to do it. I doubt I can cut through the center of the plank. (I have 2 x 6 now, and need to cut into 2 x 2's).
Would I be better off making a cut down the center of the plank using my 10" Band Saw with a decent 1/2 or maybe bigger blade? then, I could clean the edge cut back on the table saw, but am hesitant to trying without some guidance from you experts.
Thanks,
Bob
Re: Cutting 2" Cherry with old Tools
If you're going to waste that middle 2" section, then center rip on the band saw. I, however, would set up a fence on the band saw and rip three 2" (or 1-7/8+) pieces. If you follow the center-rip option, joint another 2" face then run both pieces through the old planer to take the thickness/width down to the 2" you wish. If the planer won't cut it, joint another 2" face then re-set your BS fence for 2-1/16" and rip off the 3/4"x 2" excess which might be used in another project.
paul in AZ
Instead of ripping it in one pass have you tried using two or possibly three partial depth cuts?
I've done that on occasion. Some really gnarly 2x12 inch wenge comes to mind as the worst I've dealt with. That stuff eats edges and made my saw groan. Cherry should be easier.
Too many teeth
With an underpowered saw you need a rip blade and one with as few teeth as you can find (20 or less). Then it will do fine.
Paul Leuba
I would rip three 2" pieces on the band saw. If the pieces will be blanks for use on a lathe it's not clear to me why a smooth surface is needed on the wood.
Paul in Hunt Valley, MD
Bob, I agree with all of the above suggestions.
It would help if we had a few more details. Like why do you need perfect faces if you are going to turn it? Leaving part of it square?
How much do you have to spare? Is the 6" width actually 6" and do you actually have to have 2"? If you must have 2" and Its really actually 6" then there is no way to get three pieces out of it. Well, come to think of it, you can, if the pieces can be wider at one end and narrower at the other.
Bill usually suggest very thin blades. They work beautifully. If you have a ten inch saw, put a thin rip blade with fewer teeth and it will zip right through. I have been known to rip half way from one side, flip the piece end for end and rip again from the other. That is, set the blade at about 1 1/8" high and rip twice.
The bandsaw should rip this piece without much difficulty but will not produce a face that is as nice and straight as an excellent rip blade on a TS. Neither will the double rip suggested above. This is where the extra width you hopefully have comes in. If your piece is 6 1/2" or even 6 1/4" wide, you should be able to rip three pieces out of it and still have enough stock to clean up the faces on your jointer.
Or, maybe you will have to drop back to 1 7/8" square or buy some more stock.
Bob S
Thanks for all the great suggestions! More details: I need 2 x 2 squared for top portion of table leg. Then, the remainder can be turned.
I bought a 5.9999" board, and snuck it in as a 6" in board feet calculations for paying. However, my coup was short lived, when I realized I can only get 2 blanks out of each. I saved 1/12 of the cost, but now can only get two blanks out of each section of board. I also had to buy an 8 footer, so I do have leftovers galore.
So, I do have a waste area on each, and can possibly try one or two of your suggestions.
I really appreciate the help, and had no idea, less teeth is better when making the hard rip. I thought a finish blade with more teeth was always better. WHAT WAS I THINKING!!! I actually knew otherwise, but think I forgot.
Thanks again, i'll get back at it this weekend.
Bob
Depending on how much will be turned away at the bottom you may be able to flip them back and forth, One up and one down and then saw them out with the band saw. Or you might have to offset them after the flip And cut them out of a blank 36" long rather than 30". Might still be possible to get three 2" blanks out of a 6" Blank.
TomD
Th
e basic calculation is that rips are 3 times more difficult, power wise than CCs. So your standard CC blade is 60 teeth, your standard rip is 20. Matters are also improved with thinner blades, at least power wise, if not finish or accuracy wise. A cheap rip substitute is a 7.5 inch circ saw blade, how much projection you get will vary by saw, but as someone else mentioned you can go at it from both sides if the sides are properly squared away,
When you are taking an 80t blade, you may get other details such as hook angles that reduce blow out, but also reduce cutting power further.
Rip teeth should also be sharpened straight across to reduce load on the saw. But increasingly they come alternating top bevel for some reason. This could be to make them half useful for occasional CCs, or it could be because they know many sharpeners are not equipped to sharpen square, at least as far as looking out for it and doing it. Which has been my experience, for what that is worth.
I would do these cuts with a bandsaw, but assume you don't have one...
:Re: Cutting 2" Cherry with old Tools
Bob S
Hi, Well, talk about making a mountain out of a mole hill.... I bought a 20T rip blade and went through the 2" cherry with ease. Good lesson learned for me, and thanks for all the excellent feedback, I enjoy reading it.
Thanks,
Bob
