52 Accu- Fence System
Mark Shultz
I just purchased the Powermatic Model PM 1000 10-inch Cabinet Saw. The directions say there is a "part C" that is to be adjusted that slides along the back rail connected under the end of the fence. This part is not present. Part C in the manual is called Foot. Would this be a missing part? The box that the fence came in claims the fence will ride along the entire rail without play or racking. This is not true and I believe it may be because of this Part. Does anyone else have this saw,fence, or have any knowledge about the Accu-Fence System. Thank You! Mark S.
Re: 52 Accu- Fence System
garthinsandiego
Mark - I don't have this particular fence but have the Biesemeyer and have used Delta's similar fence. I have also looked at the parts list here: http://content.powermatic.com/assets/manuals/2195075Z_man_EN.pdf.
All of these fences work by clamping the front box-beam rail between two adjustable pads on the back side of the rail and a cam lever with an intermediate "foot" (see piece 21 on the referenced parts list) on the front side of the rail. Is this what you are calling part "C"? The only adjustment is with the two setscrews associated with the pads that ride the backside of the rail. This adjustment affects the clamping force as well as fence parallelism to the blade. When the cam lever is loose, the fence should indeed slide almost effortlessly along the rail. If the fence is loose enough to cock and bind, it is also probably too loose to clamp into place. There is a anti-friction pad on the bottom of the fence toward the rear end that also aids fence movement along the top of the table.
If you are actually missing piece 21, the fence will never work properly.
Hope this helps. I jumped in here because you seemed to be getting a lot of views and no help. Very unusual for this site.
Mark Shultz
Thanks for your response. Yes,I do have that part. My owners manual shows another foot pad that connects from underneath the other end of the fence and the manual says it's supposed to touch and ride along the back rail. I finally got hold of customer support and he said that part doesn't exist and was a misprint. I guess I need to adjust the screws in the front of the fence so it will slide better without racking. You're right, I was supprised not to get a response. I thought surely someone had a powermatic or a similar fence. Thanks, woodworking communities are the best! Mark.
