What would you make this bed out of?
John Foster
Hello
My wife and I are going to make a bed for our daughter, based on a picture that she saw on the internet. The bed is sold by Coaster Home Furnishings, it is called the Grove Queen Bed # 201651Q. Judging by the price and the online reviews, it is probably a low quality piece, but we will try to make something similar out of solid woods. We are not professionals, but we can pretty much judge the proportions and come up with a solid design. Our biggest question is, what materials would you use? The smooth panels in the picture are probably some type of mdf or laminated particle board. In solid woods what would give the smoothest surface? Is there anything that would uniformly take up a very dark stain? Or will we end up painting? The rough panels almost look like pine or fir , or am I wrong? I have done similar panels either by just leaving the face sawmill rough, going to the local sand blaster and getting it scoured out, or charring it with the propane weed burner and wire brushing it after. We want to make a good solid piece of furniture, and are willing to use the best choice of materials ( excluding the super exotics) . I will try to include the link to the picture to make it easier to find. Thanks
John
Re: What would you make this bed out of?
John in NM
If it's to be painted black like that I would make the frame out of poplar, it's easy to work and will take paint well for a smooth finish.
The panels can be tricky if you want the smooth/rough contrast to be strong. Solid wood will be problematic since you will need to make the panel float in it's frame so it can expand and contract a bit with the changing seasons.
Easiest way would be to make the panel one piece out of oak veneer plywood or MDF, run saw kerfs to separate the smooth/rough panels and then fill the pores in the ones you want smooth.
Major gotchas doing this will be chipping out the veneer around the saw kerfs and being able to sand the individual panes without running over the one next to it. Both are quite manageable if you just think ahead a bit.
Most of the problem doing it this way is that the texture contrast won't be terribly pronounced since the veneer is quite thin. I suspect something similar to this was done in the picture, as that rough wood is not all that rough.
If you really want the rough look you'll have to make those panels of solid wood, which will complicate construction, but is doable. Best results I've seen for "rough" wood was to attack an open grained wood like oak or ash with a wire brush mounted on an angle grinder, then carefully sand the whole thing by hand. It was a huge pain in the neck but the effect was just what was desired - rough looking but not splintery.
Sgian Dubh
Poplar or hard maple for the framing. The panels could be MDF or plywood veneered with oak or ash for the coarsely textured ones, and veneers of maple or poplar for the smooth panels. If you wanted to coarsen the texture of the coarse panels some more you could use thicker veneer than the standard 0.6 mm thick, such as 2 or 3 mm thick, and either sandblast the surface or scorch it with a blowtorch and have at it a bit with a wire brush. To get thicker veneers you would probably need to order constructional veneers or make up thicker ones of your own.
Finish would, in my work, be spirit black dye for everything sprayed on, followed by sprayed pre-cat or acid-cat lacquer tinted with compatible black dye, i.e., spirit dye which is diluted with alcohol but can also be diluted in the thinner used for both pre-cat and acid-cat lacquer. Alternative finishing, using hand applied techniques would also work, but an example of sprayed colouring up and finishing as described above is shown below. Slainte.
Ralph Lipeles
The grained panels look like Oak to me. Some lumber yards sell the better veneered plywoods in 1/4 or 1/2 sheets. That makes it easier to get the wood home. Easier to work with and a little bit easier on the pocketbook
Ceruse finishing *LINK*
Dick Coers
I don't think the panels are rough at all. I wouldn't want them rough up against my head. Just glazed. Depends where you are located, but I prefer soft maple for the main bed, then ash or red oak for the ceruse finished panels. Takes stain well, paints better than poplar because it can be less fuzzy, and usually cheaper. You also don't have to kill the green if you are going to use dye. Personally, I would paint.
Ceruse finish how-to
John McGaw
I'd go with poplar or maple for the frame (cheap and paints well), MDF or MDO for the smooth panels (also cheap and easy to paint), and (just to be different) sandblasted ash for the grained panels. The ash will have grain to die for and which can be seen from across a room no matter the lighting. I'd dye everything black before painting to obtain a really deep look and to stand up to minor scratches.
Maple, Spray with oil based Kilz. Sand smooth with 180 grit. Spray oil based paint. The result will be smooth as glass. I am looking at some wood finished gloss black as I type this note.
A gloss black panel is going to be hard to keep looking fresh. This is not a color scheme that is going to hold up well.
A thought..... Maybe black auto body pain with clear coat would wear better. Never tried it.
Parquetry opportunity
I believe the headboard and footboard have a plywood panel, with a tongue around it, glued into the frames flush with the back side, and the front panels are cut to size and screwed to the plywood backer. That's the way I'd do it. Make the panels out of spruce or hemlock or other coarse grained softwood, wire brushed to achieve the relief you want and then sanded superficially to kill any splintery grain. The smooth panels can be anything -- birch ply, MDO, MDF, etc. Prepaint the panels with black lacquer before assembly. Gaps between the parquetry panels will not be too noticeable with the black finish.
One other note on bed-making: Use bed bolts and barrel nuts instead of those wobbly hook fasteners. I like to use 3/8" x 5" (or 6") allen socket head cap screws sunk flush with the outside surface of the legs.
John Foster
Thank you all for the replies. A lot of good advice; I don't work tomorrow, we will probably make a plan of attack and get the wood ordered. I will post a picture when we are done. My daughter and son-in-law get their new house (rental) Mar. 1st so that is our target date.
John
