Spice Box Jewelry Box- veneer and fit drawers
Now that the tedious dovetails are done things are moving more quickly. I resawed some 1/16" veneer and glued it to the fronts. I was careful to orient the veneer for each drawer as it was cut from the veneer flitches. Note how the grain flows across the multiple drawers.
It was not trivial to keep it from skidding when the clamps were tightened. I took advantage of quick yellow glue tack. I put a stiff spring clamp on the center of the veneer for about 2 min which got the tack started. Took this clamp off, added a platen and many "F" style clamps and let sit for an hour.
The next task was trimming the veneer. This step went quickly with a block plane.
I cut drawer parts to result in a too snug fit. Then I plane to get the fit I want. The sides were so limber that I had to put a spacer under them while planning to raise them to where the plane would get a bite. I used a left over veneer piece as an "elevator".
Next I need to fit in the drawer bottoms which will be 3/32" walnut plywood.
Re: Spice Box Jewelry Box- veneer and fit drawers
Ray - Middletown, IN
To stop the skidding of pieces during glue up put a few sprinkles of salt just before clamping. The grains are sharp and will bite into both surfaces without interacting with the glue.
Ray
Yonak
That's a great tip, Ray. I'm sure I'll try it soon.
joe in a Cleveland suburb
Great work.
Thanks for keeping us up to date.
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Beatiful work, I love this in walnut!
Take care, Jim
