OT - Switching to a solid state drive
David Yoho
Recently I finally had to leave behind my old Win XP box due to a problem I was not willing to spend the money on to fix. It served me well and it was time to move on. After receiving the new unit I ordered, loaded with Win 7 Pro, I proceeded to install some additional hardware inside, get all my software set up, and transfer stuff from the old hard drive. The computer was finally read to go.
Next, I decided to change out the Western Digital 500 GB hard drive with a solid state drive half the size. Since I've never required anywhere near the space of the SSD, going smaller wasn't a problem. I cloned the mechanical drive to the SSD, swapped the power and data cables making the new drive the primary, crossed my fingers and rebooted. It worked and it's fast!!!
Starting or shutting down Windows now is so much faster. In fact, my scheduled AVG virus scan is now set to scan the whole computer (all three partitions) every which way it can and only takes 5 minutes. Before it was taking anywhere from 12 to 20 minutes. The new SSD uses much less power than the mechanical drive did and runs so much cooler too. I left the mechanical drive mounted inside the case without any cables connected just in case. If the SSD fails, I simply re-connect the mechanical drive, run my backup software and everything is up to date and running again. Moving to solid state is one of the best improvements I've ever done!!
Re: OT - Switching to a solid state drive
John McGaw
Yeah. It is hard to imagine going back once the change is made. I have six computers (don't even ask) in the house and four of those have been converted to SSDs as the system drives. The newest drives on a motherboard with the newest SATA interface would even be faster but that will have to wait until the next build.
Best upgrade ever
Joe in a Cleveland suburb
I did the same thing last month to my old Win7 Pro PC.
I bought the Samsung 840 Evo 250GB. I also bought a new 2GB Radeon video card.
The video card doesn't make a noticeable difference for the most part (except for gaming where it makes a huge difference). But the SSD turned my slow old PC into (what feels like) a brand new PC. Win7 boots literally in seconds now to the desktop! Most apps load noticeably quicker too. PhotoShop, LightRoom, Nikon Capture NX2, all load faster now.
Best ~$100 (for the SSD) I spent on this old PC. I've had to rebuild it a couple times over the last few years; new CPU, PSU, Mobo, case, and more...
The only problem I had was the cloning software from Samsung did't work. I tried it a couple times and it would fail. So I used Total Recovery software from FarStone. It worked perfectly the first time.
Tony - Memphis
We are deploying several thousand of those at work. We really liek the reliability of them. Speed wasn't a big concern nor was capacity. Hopefully, the terminals that they are in will be out there for many years.
Intresting though, we have ~100k handheld terminals installed and we are wearing out the SD cards. Never thought about it, but all of these things are mechanical at the very lowest level. We write and rewrite a lot of data (not a good practice) and it physically damages the cards. Trying some new cards that have firmware that "load levels."
I haven't tried a SS at home yet. Haven't really seen the need. Maybe next time an old one crashes.
Tony
Bill Howatt
You're right about that. I image my SSD to a mechanical HD and the difference in performance on a new motherboard with SATA3 (6Mb/s) interfaces and a SATA3 drive is very noticeable compared to using a SATA2 drive.
I only put in a 128GB SSDs (you can get 256GB now for the same price) for Windows and the applications. I never store my data on the same drive/partition which is very nice for fast imaging. Actually desktop Win7 seems slow on a SSD compared to Win8 on a SSD with its fast startup method.
Bill
