Spice Box Jewelry box- dovetailing drawers
Spice Box Jewelry Box- Dovetailing the drawers
Stock Preparation To begin the drawer fronts, backs, and sides are cut to provide a good fit into the case. The lengths can all be cut the same, being sure to allow for the fact that a case back will be set into a rebate into the back of the case. It is a disaster to discover that the available length for the drawer is a rebate less than one thought, after the drawers are assembled. On a small case like this I allowed 1/8” space between drawer and back of case. To work smoothly the drawers must be well fitted to the openings. For these tiny drawers I am allowing 1/16” total side and top clearance. The openings will vary some. Even 1/32” variance means fitting each drawer individually to get a uniform 1/16” clearance for each. Hence, the front and back parts for each drawer must be cut to fit its opening. The parts are stored in the case openings they belong in as has been seen in previous posts.
PIC 1
Marking the Parts With this many parts to deal with it is ever so easy to get a part mis-oriented when some cut is made on it or when it is assembled. I double mark the parts, first with the triangle as seen in Picture 1 and with chalk as will be seen in later pictures. I chalk mark what will be the outer surfaces of the drawer and its top.
PIC 2
Laying Out the Tails Picture 2 shows the tools that are going to be used. I find it useful to first lay out the drawer dovetails, largely by eye but sometimes aided by dividing the space with a divider, on paper, as seen in the picture. When the layout looks good I can align a drawer part on the paper and make a dot on the wood at the center of the pin hole.
PIC 3
Picture 3 shows the tools for marking the tails. The dots transferred from the paper rendition of the drawer’s side are centered in the marking gauge and the tails marked with an extra fine Pilot gel pen. The Pilot gel ink doesn’t wick and it shows up better on walnut than anything else I have seen. It is not important to get the spacing precise as one’s eye is insensitive to this variance. But, tails that vary in size are apparent. The marking gauge shown insures that the tails are all marked the same size. The square is used to mark the guide line across top edge of the board.
PIC 4
Sawing Normally I use a Lee Nielsen dovetail saw. This saw helped me a lot in sawing precisely. But on this thin drawer stock the teeth on this saw were too coarse. This Zona saw shown made a good kerf, but its short height and round handle make getting it square with the top of the board unpredictable. The guide block shown was used to check that the saw was vertical before starting the cut.
I strive for functional dovetails and care less that they are visually perfect. With this many drawers to make some short cuts and insurance were in order. A most useful point was to be certain that the cut extended slightly past the baseline. A cut that stops short leaves a pesky piece of wood to be removed from the corner of the pin hole. Failure to detect this pesky piece will result in the drawer not coming fully together when it is assembled. That will leave a defect more apparent than a slightly overcut baseline.
PIC 5
Pin Waste Removal Not obvious in the picture, there is a scribble mark on each pin waste piece. It is too easy to go brain dead and chisel out the wrong piece. With these tiny pins it is quick to chisel the pin waste out. But, the chiseled out piece will wedge in the pin hole. A saw cut through the pin waste, as shown in the picture, fractures this wedge and makes it easy to remove.
PIC 6
Pin Marking It is critical that the tail board is precisely aligned to the pin board and that it stays aligned when the pins are marked. I can’t say enough how much I like the holder idea I got from Roger Lance. It keeps everything securely aligned and ensures that the drawer parts will wind up in one plane. I am fond of the Blue Spruce marking gauge for this task.
PIC 7
Pin Sawing Note the squiggle marks locating the tail waste to be removed. Again, it is easy to saw on the wrong side of the scribe line and these squiggles alert the distracted sawer to what gets removed. Sawing the pins was a problem. The thin Zona saw wanted to slip into the scribe line and the result was a slightly too narrow pin. It helped to compensate for this issue by making the beginning of scribe line less deep but I never eliminated the problem entirely.
PIC 8
Pin Waste Removal This is a tedious task. I usually chop most of it out with the band saw and then remove the corners that are left with a fret saw or the flush cut Japanese saw shown in Picture 2. I then finish up paring to the base line with a chisel. The flat sided carving knife shown in Picture 2 is handy for removing pesky corner pieces that the chisel doesn’t get.
PIC 9
Pin adjustment At this point I dry fit the joint. I make a tiny chamfer on the inside of the tails to aid starting the tail board on the pins. If in my effort to avoid a pin too narrow I wind up with a pin too fat I would normally pare the pin. But this thin drawer stock does not pare will. However, it files just dandy. Never has it been so easy to precisely adjust a pin size. I strive for a dry fit where I can press the joint together, or at most tap it together on a large drawer.
PIC 10
Glue up My shop humidity was dry and I had to work fast, even on these tiny drawers. First I lay out the drawer parts, properly oriented so as to avoid confusion. It was fastest to apply glue by putting a large drop of glue on a flat surface, dipping the spatula into the drop and then smearing a layer of glue on the surface to be glued. I assembled the joints as they got glue applied to them. ( a drop of glue is on the white plastic cup bottom)
PIC 11
Assembly I take advantage of the fact that yellow glue has little shear strength until it is full set. After assembling the drawer I snug the joints from each direction with a clamp. The clamp squeezes any extra glue out of the joint. I find that I get tighter fits if I pull up the joints with a clamp.
However, clamping may pull the drawer out of square. After pulling the joint together I remove the clamp, check for square, adjust as needed and put the drawer into its opening to cure the glue.
It remains to veneer the fronts, install the bottoms and final fit to the openings.
PIC 12
