Help
Help
Help
Molly
hi there we are having a hard time trying to bring his wood that we sanded too much back to match the table any suggestions would be helpful we thought it was teak now wondering if it's veneer attached are some photos thanks.
Re: Help
Re: Help
john Veerkamp
Photos?
Re: Help
More info please
Dick Coers
like what you've tried, what materials you are using, etc....
Re: Help
Re: Help
William Duffield
To figure out how to post photos that we can see, so we can give you some real help, you will need to "read, understand and follow"* a few of the WoodCentral FAQs. A link to the FAQs can be found in the grey box near the top of most WoodCentral pages. Specifically:
Q: How do I use your messageboards?, points 2 and 3;
Q: How do I upload photos with my messages?
Q: How do I reduce the size of pictures so that I can post them on WoodCentral?
*literary allusion to the New Yankee Workshop
Re: Help
Making a good first impression
Molly, this site is populated by knowledgeable old farts like myself that don't Twitter to others. Personally, if someone is asking me to spend some time to prepare and type a detailed and thoughtful response to a question I expect the person asking to take the time to formulate the question in acceptable English.
The conventions of English- capitalization, punctuation, etc.- evolved because using them resulted in better communication. Reserve the Twittering for things unimportant.
Re: Help
Re: Help
TomD
If you have Flickr or something similar, either give a referring URL, or you can put the JPG url in
A lot of teak furniture was made with veneer. You can tell if you look around an element, say a table top, do the edges look like a real board (no joints there should be a visible end grains, and visible side grain). Is the underside some other kind of wood, perhaps plywood, though on better furniture it might have been veneered also. Another tip off is if the wood has a repeating grain across it with straight section and cathedral sections. Worse still is if you were sanding, and you went through into some stuff that looks like glue, or totally different wood. That would be a bit of a disaster, not easy to fix convincingly, but you will have determined that you were using veneer.
Re: Help
Re: Making a good first impression
TomD
It's a two way street. Checks in boxes for vulgar, rude, and ageist, with others possible. That could really pack a Tweet.
