Rust Fairy
Rust Fairy
Rust Fairy
Joe
I've finished renovating my house and started to move my equipment from my old, wet garage, (didn't renovate garage), back into my new/ old shop. Rust is everywhere and I was hoping someone could send a rust fairy to me with a good idea of how to mount a major challenge.
Re: Rust Fairy
Re: Rust Fairy
del schisler
this is what i use and no rust, i live in fla. this is where i get it , their are other places that carry it http://www.sears.com/boeshield-t-9-rust-protection-cleaner/p-00928468000P?sid=IDx01192011x000001&kpid=00928468000&kispla=00928468000P&kpid=00928468000&mktRedirect=y
Re: Rust Fairy
Start
with an application of phosphoric acid to chemically halt the oxidation. You'll find the stuff under various brands like "Must For Rust" or similar. The rusted areas will turn black when the iron oxide is converted to iron phosphate. For machine surfaces, I then work the surface with steel wool and oil. Lastly wipe dry and then paste wax. Hand tools and such get treated and the buffed with a wire wheel, but you can go whole hog with the electrolysis thing if you're really into it.
Re: Rust Fairy
Re: Rust Fairy
Pete in Holland MI
Steel wool & WD-40 if the rust isn't too great. Do it on my wood lathe regularly after turning wet & acidy woods.
Re: Rust Fairy
Kneale Brownson
Second this.
Kneale Brownson
Most of my equipment sits in an unheated barn on a concrete slab that darkens with moisture in a humid setting. But I'll clean off the oil with mineral spirits and then spray a couple coats of Top Cote by Bostik. I use that product on most of my metal tools too. Never have the rusting I used to experience.
Re: Rust Fairy
Re: I do exactly the same.
I rarely have any "rust", but do get light staining, have purchased some items that have had rust and used the scotch pads and oil, sometimes WD-40 or other light oil. When the rust has been removed I either use Top Coat, wax or Boeshield T9. All work quite well in my shop, but it is heated and Air conditioned so is a good environment to prevent rust.
Re: Rust Fairy
Re: Scotch pads and light oil
BrianMonumentCO
There are scotch pads (under other names) that are less abrasive and may cause fewer scratches if that helps any. I get a variant that is white that is soft enough that I can use it with oil on blued gun parts and it doesn't hurt the blueing. It does remove light rust.
Re: Rust Fairy
good point
I jumped to the conclusion that we were talking about more serious rust. For light rust on cast iron I use steel wool and light oil (WD40 is good).
Re: Rust Fairy
Jumping to conclusions
David Yoho
I'm guilty of concluding which Scotch Brite pad you were referring to. Although I have most of the colors or grits, probably the most thought of Scotch Brite pad is the green one. I actually thought of the grey pad because that's the one I use on light rust in the shop.
I use the white ones for times when I need some scouring action but without the grit. I use the green pads mostly during stripping finishes or when I want something more aggressive than the grey pads. So, although I have the other grits, the ones I use the most are the green, grey, and white.
For light rust on cast iron I usually use the grey with some WD40. I use the WD40 for its solvent (since it's not a lubricant at all) and water displacement ability. Then I scrub on some Johnson's Paste Wax with a grey pad and wipe it off with a rag.
Re: Rust Fairy
Re: Rust Fairy Thanks you
