Anybody got a humidifier you like?
As a Home Inspector I have been taught to dislike and distrust humidifiers. (Danger of leaks and they are often mold factories.) But as I age I find my hide is giving me fits in winter.
So, does any body have a humidifier they really like? I have a heat pump and due to space restraints I may not be able to add a whole house unit. Probably looking for a large room unit. Preferably low/easy maintenance.
Re: Anybody got a humidifier you like?
April-Air
is pretty much standard in my area. Used them for more that 20 years without a hitch. DO require a bit of care in that you MUST change the media pads EVERY year, have the proper valving to shut them off once the weather warms, and have them drtain into the AC condensate pump which needs to be cleaned twice a year.
Re: April-Air
CJ in MPLS
Just be careful with the settings. I've woken to find water on the walls when I had the thing turned up too high. Other than that, works a charm.
Don Evans
You can add a whole house one, as it will go where your heat exchanger and duct work is located. If it is under the house that is best place.
I would recommend the one I have soon as I remember what the name is, I can look it up if you want to check it out but it is a heat the water to steam type and puts the steam into the plemum. Also you should get a 8000 or 9000 series Honeywell thermostat. It will control the heat and air cond. and the humidifier. It works great in that it not only lets you set the percent of humidity but also it has a frost setting. You will set the frost so that water never forms on you windows and from that point on it will keep the humidity as close to your setting as possible.
Example: I set humidity on mine to 45 percent and learn I need frost setting on 4. The other night when it got down into the 20's here I notice the humidity had dropped down to 39 percent that was the frost control in action, next day when it got warmer humidity came back up to 45.
It is also a 1 deg thermostat fyi and this humidifier will also need a drain line as it flushes itself ever 12 hours but that shouldn't be a problem either as you have one on the heat pump so this one can go to same place to exit house. The pvc for this drain is high temp water pipe so don't splice it into HVAC drain line.
The humifier is a Honeywell it's the model I cannot remember.
Don
Playing the Percentages
Humidity is, like that never-met cousin who's been in the Bayou swamps for 30 years and just appears on your porch, relative.
Humidistats need to be adjusted as the outside temps change up or down. A settling that gives 45% humidity may be just fine when its 45° outside but you'll have dripping walls and rotting window sills when the weather drops below freezing outside. We have 2-zones and a number of skylites in our place so I have a pair of digital sensors that I check periodically. I adjust the humidistats on the furnaces to keep the house close to 35% during the heating season. Lower than that we get static shocks. Much higher and the skylites start condensing and dripping.
Large Room Portable Unit
Tim Greif - West of Chicago
We use a Lasko 1128. This thing has a capacity of 9 gallons a day. I have a 3200 sq ft home with dual furnaces, so I went with a portable. My last house had a whole house unit on the furnace ductwork and I hated the thing due to the maintenance. Back then we had very hard water and the calcium deposits on the media wheel and filter was horrible.
The Lasko uses about 3 gallons of water a day for us and we only use it when the outside temps are below freezing. Dry air doesn't bother me so much, but it plays hell with my wife's contacts and sinuses. If you have two stories and choose a portable, put it on the lower floor. Contrary to popular belief, moist air is lighter than dry air, so the moist air will rise to the second floor. Pop in a new $6 filter every year and you're all set. However, you do still need to carry the included 1.5 gallon jug of water to it multiple times a day. Holds about 4.5 gallons.
Re: Large Room Portable Unit
Joseph Mulherin, sr
Use distilled water to get away from the calcium problems....a little expensive but well worth it I believe.
Grant in Iowa
We use a large portable for our home. It lives in the basement and gets filled every other day or so when it is below freezing outside. With two people in our five year old 3600 square foot home, we don't make enough moisture with our own activities, and need a boost with a humidifier to keep from having skin issues in the depths of winter. And, I like to avoid the wooden items in the home from moving more than necessary. <- might be my main reason, really.
We like the portable because I can easily see all of the parts and can therefore continuously monitor any mold growth. And, when it fails, I can buy another one easily. We humidify to about 30% RH, and don't try for much higher. Most sizing charts are for people desiring 40% or more RH, so they get sold on thinking a portable unit will not work for them.
No way would I install one on a furnace. Even if you have your ducts cleaned regularly, you are basically creating a large mold and mildew machine. Ask any HVAC guy, or home inspector (who doesn't sell them). Most of them will have seen what the inside of the supply air ducts look like after a few years of running an attached humidifier. I don't get too bent out of shape about mold, but this is one mold maker that is easy to avoid.
Commercial systems use steam introduced to supply air ducts, which is a notch better but still a mold factory long term. It is better because the steam better dissipates into the supply air stream, and is less likely (though still pretty likely), to condensate within the ducts. Such systems can be had from Honeywell, if you have your mind set on such a system.
FWIW,
Grant in Iowa <- Facility manager in a large museum where we make lots of humidity
We have a honeywell portable, by the way (nm)
