Hose Length??
Hose Length??
Hose Length??
Tom
I have a question about hoses for my HVLP set up. I am thinking of using my set up with a 1-2 gal pot for spraying acrylic stain on the exterior of my house this summer. What would be the longest length hose set up I could use?
Re: Hose Length??
More info?
Keith Newton
What equipment, and size hose?
Re: Hose Length??
Turbine or Conversion Gun?
Serious doubt that a trubine will "push" the material more than a few feet over your head, if even that high. A conversion gun working off of a compressor with enough juice should do well. I would not, however, count on a small compressor to do the job. To get 25' up the house you'd need 8-10 CFM depending on the weight of the material. This "stain" is one thing, latex/acrylic (actually thin paint) will be very different and you will need to change your needle and air cap set.
You might do better renting a airless or air-assisted rig. They move a lot of paint quickly.
Don't forget to do the serious masking of window etc. Don't do this on a breezy day. If you want maximum coverage and penetration, apply by spray and then work in with a 6" brush.
