Pros
TomD
We have a certain amount of discussion about what the pro opinion is around here, and what it means. Currently I am measuring up my daughter for online glasses, and you have to make some guestimates as to what is what. This would be an ideal situation for using a pro, but...
I just went through this with my mother, who can't see through her glasses to drive. Part of the problem seems to be that the glasses are too high on her head, and she is forced to look through the bifocal component. I got her talked around to driving glasses, but she was getting here graduated lenses anyway, so I sat in on the fitting. Like most Optometrists, the fitting is done by an assistant, a very smart and energetic individual who is, like 6'6". No idea but she was taller than me at 73 inches. So she has a number of machines to run my mom through, that go beep when the result is done. Then she measures her for the vertical centre of the lenses. They are sitting opposite each other, and the technician scrunches down to be at the same level as my 62" mother. She is at least 4 inches over 4 feet taller when she takes the measurement. Therefore the lenses are going to be ground with the papillary center a good deal high.
So in the real world, pros with thousands of dollars of gear and decades of training should get better results than old carpenter/shooters, but you can't actually count on it. It should be a shortcut to send your numbers to China, but at the end of the day it may not be.
