Re: Wooden boat glue / need to join dried cedar pl
TomD
What are we looking at there, is that a floor, or the inside of your hull?
You really need to get very specific advise, I wouldn't just randomly ask on the net.
1) Is this a restoration? Not my areas of specialty, and you get into all kinds of functional issues combined with preservation issues.
2) you want to rebuild the boat for best possible life here on out, and don't care about how they used to do it.
Best cedar hull will be epoxy sheathed with glass. How you go about doing that is a very specific issue. The outside can be cleaned to bare wood, then you may need to use some technique to rout out the seams, then you squeegee in glue, sand and fair. Then as a final deal you sheath the hull.
Now the best new build way to do that is normally to sheath the inside, you have to stop one moisture from getting in from behind. The ribs will stabilize the inside, but you still have to control absorbtion of moisture, and with the latice work of stuff you have there, it will be hard to totally seal it. You need a very specific solution.
Just throwing glop into the cracks is probably not a good ideal. I would not use resorcinol on anything, really today, but in particular not a bunch of cracks (but then maybe there is som 1) reason for doing that, there isn't nay boat building reason for it. There would have been an old process, like white lead, or something, but I don't do that stuff.
Epoxy is your ultimate wood salvation, but you have to be able to get it on clean wood, and on all surfaces, and no penetrations. If you can't do it the right way, epoxy can make maters worse. Lots of runabouts have been epoxied to beautiful shape, and there is some free info out there. Try the Gougeon site:
http://epoxyworks.com/
http://www.westsystem.com/ss/assets/howto-pub2/Wooden%20Boat%20Restoration%20and%20Repair.pdf
