THE WOODRAT IS BACK!
wooden bearings *LINK*
Lars Parrington
Stumbled upon this study of wooden bearings, and thought it might be of some interest to others here.
There's some good data about which woods and lubricants work best, and the surprising result that using a hardened & ground steel shaft results in drastically worse performance than plain old cold rolled steel.
http://www.uidaho.edu/exit//~/media/Files/orgs/CNR/Fire/Forest%20Products/Thesis%20and%20Abstract/Sathre2.ashx
Re: wooden bearings *LINK*
My experiences
I used a product called Arguto Wear Strip as a support slide on a dining table I made thirty years ago. It is a silicone-oil-infused hardwood material (birch?) that retains its lubricating properties over time. They use it for conveyor belt systems in industry.
In the really old days --late 70s, early 80s -- I used to go to the docks in Brooklyn, NY, to buy all my exotics. In those days, they had lignum logs piled up, skids full of Brazilian rosewood, tulipwood and English oak and other stuff too painful to recall. They also had lignum pillow blocks, which were used on marine propellor shafts. I think lignum vitae is still the benchmark, though nobody is making these things anymore, because they've cut down all the lignum trees that are big enough to yield suitable sized bearings.
Ah the memories...
Ah Yes, Back in the good old 70ies.
Keith Newton
That was about the time Jed Clampitt left here with the family to head out west. I think I recall he had trouble finding lignum even then, so had to settle for Dogwood, even though Granny wanted Slippery Elm, because she could make a potion out of the bark while harvesting. Ha, Snark off
Ellis, I'd like to have seen those logs, and just wondering what size? "lignum trees that are big enough to yield suitable sized bearings"
Re: wooden bearings
Rum
Thanks for sharing this Lars, it was a really interesting read.
It has some direct bearing on my interests in quasi primitive yarn processing tools which often have a shaft (or shafts) running directly on either wood or leather bearings. The good performance of bees wax was useful to know, I'll likely try to convince loml to allow me to try a few experiments on some of her equipment, mostly she's been using something akin to a medium weight motor oil (low sulfur, yadda yadda) but some sort of non drying oil (delivery), beeswax (stickum) mix might well perform better for at least some uses.
I think there could certainly be a bit more experimentation done on the shaft properties, I can sort of understand the results they got, but they are certainly a little confounding from my base expectations and do wonder if there are other ways to improve the situation and what the some of the specifics where (how polished was the polished shaft? Is there a break over for that? what happens if you do the final polishing in the other direction?) Don't expect I'll have time to ever answer those questions via direct experimentation but would be interesting.
Re: Ah Yes, Back in the good old 70ies.
Mark Hennebury
Back in the early seventies, i could get Lignum blocks from the dockyard in St Johns Newfoundland.
I understood at the time that they were used for bearings on propeller shafts. I remember seeing blocks that were about 4" thick x 10-12" wide and about 3-4' long. Most had a small bit of cream colored sapwood on the edges. I acquired one to make some things out of, I still have a mallet that was made from a piece from that block. I remember that they were coated in wax.
That is a serious chunk of wood, incredible heavy and tough to cut.
Re: Still being made
TomD
Last time I googled, there were still several companies making wooden bearings.
Here is the first one to come up:
http://www.woodexbearing.com/
I know a guy.....
Who has a shed full of Lignon Vitae, probably a tractor trailer load, among many other things. It may be a million dollars worth. I was drooling, looking for a "little" piece he might sell cheap. He just laughed and said that when they saw it they even save the saw dust and sell it to the pharmaceutical industry or maybe it was the cosmetic industry.
He's the guy that bought the Atlantic city boardwalk. Hauled it back to VA in tractor trailers. They are resawing the beams, cutting about 1/2 inch off each side to clean them up. A huge amount of rot resistant rain forest stuff. I don't remember the species, but there were clearly several different ones involved.
Some astounding pieces there. Lots of stuff Nakashima would have liked to have.
He's the guy that quarter sawed my white oak.
Lars Parrington
Agreed that some more experimentation around different shaft types would be useful.
I found it pretty interesting how much better beeswax rated than paraffin, which is my current go-to wood lube. I'll definitely have to try out some beeswax in the shop too. I wonder if it would make a noticible difference on the bottom of my stanley planes.
speaking of yarn tools, have you seen my yarn winder? ;-)
http://lllars.appspot.com/special_projects/yarn_winders/index.php
Re: I know a guy.....
TomD
Interesting guy to know!
TomD
http://www.rainforestrelief.org/What_to_Avoid_and_Alternatives/Rainforest_Wood/What_to_Avoid_What_to_Choose/By_Product/Boardwalks.html
Claims to know what the wood is.
The logs I usually encountered at Marshall's were about 8" - 12" in diameter and 4'-6' long, but I often saw machined pillow blocks that were 6" x 8" x 24" long or even larger. Every now and then, I saw lignum lumber that was over 18" wide. Those trees were few and far between even then.
Mark Nowicki
We had the shaft blocks replaced on our ship in 1979 at the Alabama Drydock Company.
The bill for the wood itself was $35K.
Mark
who knew?
hennebury
I wonder how much wood they got for that amount.
That got me a little curious and had a quick search to see what info is out there on the current uses of lignum, I found this company website and read through it and watched a couple of their videos, quite fascinating.
They use lignum bearings in the turbines of hydro electric plants!
http://lignum-vitae-bearings.com/wood-bearing/
https://www.youtube.com/watch?v=-yc_VqgePkU
https://www.youtube.com/watch?v=-_MEn8JBJLs
Re: yarn winders
Rum
A bit delayed on this one :D
Those came out really nice Lars!
I was thinking about punting and just doing the gasket friction "gear" for both pieces, but the wooden gears are certainly a nicer touch. Neat design on the side teeth on the front gear.
I can't let loml see your shoe stand either!
Re: yarn winders
Lars Parrington
Thanks!
The crown gear (side tooth gear) is a pain in the butt to make, but regular flat gears are pretty easy. You can print out a template using the gear generator on woodgears.ca, and then cut it out on a bandsaw.
The shoe rack is pretty easy to make. It is all knockdown joints, so there's barely any gluing to worry about, and it's easy to finish before assembly.
