Walnut color and how it changes with time
The walnut board on the top was sawed about 1975, then air dried, planed and stored ever since in a single board-wide stack in a dimly illuminated loft . Dim light fell on the edge of the stack that this board was within, but not its surface.(it was in the middle of this stack , not on top)
The board on the bottom was more recently sawed, it may or may not have been kiln dried(doesn't matter to color), it definitely was not steamed(matters a lot to initial color) and it was planed a few minutes before the picture was taken. Hence, its surface has only been exposed to light for a short time.
The bottom board shows the fleeting color typical of a freshly exposed walnut surface. Without some treatment to exclude light and oxygen this color will not persist.
The top board shows what happens to the purplish color of freshly exposed walnut after exposure to light and oxygen. Even in subdued light the color changes from purplish to yellow-brown. One can clearly see the change in color and bleaching from the edge of this board that was exposed to the dim light to the center which was covered by the board above and below it that largely excluded light, but not oxygen.
The lesson here is that walnut color is not lightfast. Finish may alter the bleaching process and the eventual color the walnut arrives at by slowing the effects of light on the wood coupled with the coloring of the finish by light and oxygen.
Re: Walnut color and how it changes with time
David Hay Denver
Thanks, Bill. I've always wondered why older walnut furniture (especially the mid-century modern stuff) had a warmer, less purplish color than the walnut I've been working with.
Do you know if there's a way to accelerate the color change? Or perhaps there's a stain that helps approximate the color? I read about a process involving an orange aniline dye and shellac that imparts a warmer color, so I'll experiment with that. But I'd love to hear of other suggestions about how to get that nice warm brown color.
David
suggestions
put the fresh surface in your summer sun for an afternoon and the purplish hue will be history. It will take a little longer in a south facing window in January.
Or, stain. I stain nearly ever walnut piece that I make. Shown are some recently made drawer fronts stained with "burnt umber" pigment stain. The burnt umber give the wood a redish hue for a few years changing to less redish over time. The drawers were photographed the day they were stained. The drawers were photographed some years after staining. See my Gallery in the WoodCentral Gallery section for more walnut color.....all stained with burnt umber pigment.
don stephan
David:
Several times I've seen a suggestion to add some orange color to steamed walnut to make it look more like air dried. Usually the suggestion offered orange shellac as the easiest and fastest way to do this, during the finishing schedule.
Steamed, KD, air dried.......
....doesn't matter in the long run. It will all look the same after some years of exposure to sunlight. These two test pieces were split from the same freshly sawed board. One was steamed and came out of the steamer nearly black, as usual. Both were then air dried ,the surfaces planned, and put in a sunny Tennessee window for about two months. In this shor t time in a sunny location they have become nearly identical.
