Re: recommendations
TomD
I agree with most of what Bill said, with a few exception:
- #2 common was what Maloof ordered, I believe, at least at the time he wrote his first book (and that was presumably some kind of California walnut {they have stuff from all over the world} so it would be different to boot). But the principle is the same. And that is that by the million bft where you are taking stuff like flooring, the junk wood is not appreciated, but it is exactly the stuff you can find your pieces for studio quality work. You need character, you need grain that runs in odd directions to mirror parts and so forth. There will be waste. So commercially mark what Bill said, but for high end furniture it is not the same issue. You get a lot of dead straight walnut, you have a lot of boring wood.
- You need a fair amount of quartered wood to make real furniture. Though depending on how you saw the wood, it can come from flat sawn wood. So you need a quartered 1x2s to get your frame stock out of, or you need to saw some 8/4s and rip it off the edge of the board. If your pal flat sawed the whole mess there is plenty of quarterd yield from the heart slices, but you need to keep your share of that stuff for cabinet uses. There is a fair amount of cabinet wood that needs quartered stock, but you can find it without quarter sawing. I have no idea who has the gear to quarter a 36 inch log, while I nearly have the gear to flat saw it. Also keep in mind that quartered wood will all comeout half or less the width of flat sawn, and part of the appeal of these large logs is the width of the boards. You will take a hit of the bft rate if you make them smaller. Though selling really large boards is harder, in general.
- If you are sawing for yourself, saw it mostly 6/4s 8/4, and some even larger. I am sure Bill knows the commercial world, but you have much better luck air drying bigger stuff, and you will have much more versatility if you leave it large. Plus it is sorta less work. You have no idea how many stickers you would need to cut to lay up 4/4, with larger stuff you will have greater stiffness, therefore far fewer stickers, and to boot you have many fewer boards. They will be heavy though, but I can't help you there. The wood does slide around easily when it is wet and dusty.
So the main issue is cash or craftsmanship. If your friend just wants to convert to cash, then read what Bill wrote very carefully. If you want to keep some or all of it for local woodworking clubs, your own high end stuff, then the cut is different, and you need to think of what goes into a piece of furniture. There is often one or two pieces that are really large, like a carved apron, and nothing feels more ridiculous than doing custom sawing only to find you have all the stuff they sell at home depot, and none of the wood that you need for real woodworking projects. Just recently I scored some heavy maple, perfect for the next bench legs I make, you can't get that out of 4/4s. But equally if our 16x4 inch salad bowl blows after 20 years, I can cut a new one out of it, or if I want a jointer plane. And along the way, I made one cut for the 4 the 4/4s would require. I sealed the ends, and there is no visible checking.
If you want to saw out a few full width pieces for, say a church alter, live edge, then you might find a local guy with a chain saw.
I have no idea about liability. When I do this stuff I treat it as an adventure and if it kills/maims me I figure it might have been some other thing I like to do. But when bringing in people, one would need to know where one stood, because these logs are dangerous in a lot of different ways.
