The truck door key was not working reliably. Lock place squirted some magic stuff from an aerosol can into the lock and all was well again. Looked like WD 40 but wasn't. Was told it was some expensive stuff for guns and that WD 40 would just gum up the works. They would not sell me a can.
Any idea what this stuff was or what would work in the future?
Usually a graphite spray, some with PTFE. Any auto store sells the stuff and lots of different brands on Amazon. Silicone spray is also used to displace water condensation on the internal parts.
Bill, I normally use graphite on all my locks, it works wonders. I have raw graphite powder in a tube. I also have (may still have but don't remember where I hid it) some in a small flexible tube with a spout that fits in the lock openings. The automotive stores used to sell - probably still do, a small pressurized tube containing alcohol and graphite mixed, advertised to de-ice and lube automotive locks, it works quite well. When I use the pure graphite in powder form, I just spread as much as I can on the key and insert it in the lock, work the lock a couple of times, recoat and repeat until the key slides in easily and the lock works smoothly. It is a "dirty" operation and will leave your fingers black, but washes off pretty easily with soap and water. Been using it this way for many years, just fixed a house door lock for a friend a few weeks ago.
I live up where it is pretty cold -20C at the moment. And I use WD40. Never had a problem. It would help to know what environmental or other factor you are trying to deal with, so we could specify shampoo or conditioner, as required.
While I buy graphite powder by the 1 pound can, I doubt that is what they used because the stuff is dirty. A gun product that is a little similar is Moly Lube. Theoretically, presumably actually, Moly bonds to metal in a somewhat permanent way, and after that is dry, and it lubricates.
Tri flo, and Break Free are good gun products, you might spot your product if you googled those.
Lock picking was one of my first crafts, the supplies are now generally available. Here is an article on lock lube products.
But I recently had one lock that was sticky but couldn't find my bottle(s) of graphite (either of them.. since found) so grabbed something else I've been enjoying lately for similar purposes (as a spray on dry lube for machine parts mostly):
CRC 3-36 Multi-Purpose Lubricant - aerosol.
I gotta say it worked better than the graphite to free the lock up.
The jury is still out as to how long it will last in this use case.
It was one of the things we used to cure scratchy volume controls in stereos back when people fixed such things rather than tossing them and buying a new one.
I never knew it was such a fancy product as the locksmith has told you
When I was in HS, it was also the only can of stuff that had a nozzle you could take off and put on a can of shaving cream, leading to much unscrupulous hilarity
As a facility manager for a 100,000+ square foot operation, I have a few locks to maintain. We use a product called "Houdini" to great effect. Got turned on to the product by our local master locksmith. About $10 for an 11 oz. aerosol can with a handy straw. For what it's worth, I'd find a different locksmith if he is that unhelpful.
I have all but stopped buying WD-40 for any use. I keep spray silicone on hand for lubrication, Houdini on hand for locks and small parts (because it smells nice and cleans up easily), and use actual grease on anything with lots of movement.
Back in the good old days, when locks were purely mechanical contrivances, graphite worked fine. Security systems are becoming more and more reliant on electronics. Inside your car door, for example, you will probably find a plethora of electrical and electronic components. Graphite is a conductor of electricity, while PTFE is a dielectric. I originally sought out the PTFE because I was having lubrication problems with the plastic hinge on a laptop. It works well in that application because there are many electrical wires routed through the hinge, and the quickly evaporating propellant (most probably propane) causes much less damage to plastic components than heavier petroleum distillates. So when I had a recalcitrant lock on an entry door, I used it, very successfully.
I do not bring graphite based spray containers into the shop, because I have lots of electronics that I don't want to fail the smoke test, including such things as laser line level, moisture meter, metal detector, remote control dust collection and air filter, shop clock, iPad, MP3 speakers, digital camera, electronic speed controls, cordless phone, batteries and battery chargers, universal motors, work lights, and a SawStop. I could do a lot of damage in a hurry in moment of inattention with a can of graphite lube.
I keep this around the shop, and think it is one of the best lubes I've ever found.
I had to use it a while back on my camera. The zoom lever was getting catchy. I knew better than to just spray it into the space around it, but sprayed a little onto a scrap, then used a fine artist brush to go around the outside, and the problem was solved.
It is a little too slick for some things around the shop though. I thought the threads on some of my hand-screw clamps needed some lubricant, so I sprayed it on, then spun them in and out a few times. But when I tried using the clamp, I found that when I turned down on one screw, the other was unwinding, letting the pressure off. Luckily I have about 30, so I grabbed a couple of others to use, Then used some solvent to clean them up after the work was all clamped.
It ought to be great on locks, since it also displaces moisture, and prevents rust.
It does not appear to be the same concoction I'm using, but that's really hard to tell for sure. Curiously, the HDX product I got at the Orange Borg has disappeared from their virtual shelves.
Your experience with hand screws (some of my favorite devises for application of pressure) is very useful. I'll also try to remember to keep it away from my holdfasts and the heads of my hammers. ;^)
