ADVERTISE HERE - FREE TRIAL
poor feeding on Delta 12.5" planer
cameron
My 22-560 planer is getting up there in years (>10) and has run well >1000 bf of lumber. I am really struggling with this thing lately in that I can't seem to keep the feed rollers clean (primarily the infeed). I have to take very light passes but even with that I end up with chips and dust coating the roller and then the boards surge and get stuck. I typically wipe the rollers down with a solvent (acetone, mineral spirits etc) but my latest poplar run may be the last on this thing unless anyone has any suggestions (had to brush every ~6 passes...) I don't see any obvious dust collection issues, the blades are sharp, I run on a melamine substrate and I'm at a loss, wondering if wear and tear has finally gotten the better of this thing.
Thanks
Re: poor feeding on Delta 12.5" planer
I have a Dewalt lunch box planer, so my experience may not apply. It sounds like you have done all the right things. I wipe my rollers with alcohol. Something that leaves them clean but tacky (grippy, whatever that is). In addition to all your things, I found that the bushings that support the rollers had wallowed out a bit and needed replacing. The drive chain had a stiff link and was causing the roller to bounce, leaving a very faint line on the piece. I replaced the bushings and the chain and its as good as new. (well, a lot better.)
Also, check the dust collection carefully. I had a big shaving stuck in mine and that appeared to affect the suction. Maybe. May not take a lot to change things.
If dust and chips are sticking to the infeed roll it seems evidence that this dust and chips are not being ejected from the machine effectively. I can not imagine any wear issue in the machine that would lead to this result.
The reason could be ineffective air velocity from you dust collection. As a test, try running the machine and simply blowing the chips out on the driveway, or whatever, without dust collection.
Or, maybe you have made the rolls sticky by the solvent treatment, something that I would not recommend. If the rolls don't grip without solvent treatment it may be that the polymer has degraded and gotten hard. Replace rolls.
Winter planning conditions. If the lumber is very dry and the air is similarly dry static cling can be a problem. I have had dust coat even metal infeed rolls, and the whole machine!, under such conditions unless I had a tornado of air velocity from the dust blower.
Keith Newton
I seem to remember having an issue with the chip deflector on one. I I didn't see where you mentioned having a vacuum on it, but if it does, make sure it is working properly.
cameron
I have this connected to my vacuum system which after replumbing the lines to run under my new concrete floor is pulling better than the past 13 years. I have not taken the dust shoot off but I will take it apart and see if something has obstructed airflow in the machine. The static is a good thought... My shop is definitely dry and poplar's density might make it more susceptible to static forces.
Bruce, a MN Galoot
I have the older model of yours, a 22-540, and I have feed problems in the winter, too. The problem is attributable to one thing, the feed rollers. My shop is unheated, and the 20+ year old urethane feed rollers get very hard and won't grip properly. I never used to have this problem, and the planer has never lived in a heated shop. Unfortunately, replacement rollers are now discontinued. The solution will be one of two things: 1, stop planing in the winter or 2, get a different planer. I'm probably going to get a Makita.
We sold lumber for many years. In the winter we had a time planning freshly KD poplar when the humidity was low. The dust clung to the machine and everywhere. Sometimes in desperation we spritzed the surface with water. Then we got a bigger blower, vastly bigger than any home shop, for the dust pick up and that solved the problem. Now this was on a machine with metal infeed rolls. I would think polymer rolls would be more problematic.
cameron
I'm trying to talk myself into a new planer but the cheapskate in me is reluctant. I'm sick of the extremely loud motor noise (and sure the neighbors are too) and I know that there is wear and tear on the machine (the lock mechanism has gotten catchy, there is detectable slop in the trunions when adjusting the height, etc) but it's hard to justify the large expense if I can still get boards through this thing. The aggravation and need to take very shallow passes are adding up though since my time is precious. I will probably end up replacing this thing and have been debating on a stand-alone planer (like the grizzly or Powermatix (sale this weeked at Woodcraft) spiral headed 15" machines) or one of the 12" combo jointer/planers (have an 8" jointer now...) I'll attack the static issue tonight and see if that helps.
3rd choice
Get an old Parks, Delta or Powermatic 12 or 13" machine with cogged infeed rolls. It will last several lifetimes of use.
Make Sure Blades are Razor Sharp
Ron in Sterling, CT
I know you said your blades are sharp, but ... Last summer I was planning pine with my Dewalt and the same thing happened to me. I stopped, and cleaned the rollers good, but no help. I thought the blades were sharp, but decided to put on new ones anyway. Problem solved. I was amazed at the difference. May not be an answer to your problem, but thought I would pass on my experience.
Ron
Re: Make Sure Blades are Razor Sharp
cameron
I'll give that a shot. I replaced the blades 1 project ago (run ~150 bf of QS white oak) and assume that they are still in good shape but maybe they need to be replaced...
Re: 3rd choice
Bruce, a MN Galoot
I'd love to do that, Bill, but my shop is teeny, and there simply isn't enough room for a floor model anything.
dull blades my experience
Wax the bed
Alan
I have this issue occasionally, and my planer lives in a heated shop. I just wax the bed. The boards slide easier so the rollers don't have to work so hard. Last month the belt wore out, after >15 yrs of moderate use. Replaced it and it blew out again this evening. Took out the belt guard as well. Used lock tite on the nut, but not enough apparently. I'm also cheap and trying to avoid replacement, but it's so old that the replacement belt guard was discontinued and hard to find. Will throw my last set of blades on it when the parts arrive and hope it lasts a bit longer than a month this time.
planner rollers rebuild - place for that
del schisler
i did a google search on rebuild and got lot's of sites
http://www.google.com/#q=planner+rollers+rebuild
cameron
Well I changed the blades tonight and they definitely needed it, I got a much better finish afterwards but it didn't help the feed-roll clogging up. I had been sticking a brush in there while the rolls were turning trying to clear them off at which point I finally realized that the chips weren't stuck to the rolls but rather clinging due to static, just like what was mentioned in this thread. I guess that's the price to pay for planning in the dry winter with a non-conductive roller... I had to manually push each board through to get through my pile of poplar. Thanks guys
David Yoho
I started out with a 22-540, and now use a 22-580. Mine does the same thing this time of year. Just used mine yesterday and had to take the old tooth brush I keep handy to swipe away the static chip build up. My planer sits next to my big dust collector so I know it's not due to enough suction. My planer still feeds the boards though.
A trick we used often in my former job as an Engineer to eliminate static electricity was to spray or dip (if plastic storage containers) the items with a mixture of liquid Downy (or other clothes softener) and water. As I recall the mix was 50/50 or less Downy. We put the solution in a spray bottle (like a Windex bottle) and sprayed down workstations, carpet, floors etc. This causes the object to be hygroscopic (draw moisture) and electrically conductive enough to "ground" the static electricity. You also may try wiping the rollers and other offending areas with a softener dryer sheet. Should eliminate the static problem.
cool idea
David Yoho
I'm going to try that. I'll report back.
