THE WOODRAT IS BACK!
Joined the club...
Joined the club...
Joined the club...
Tony - Memphis
Well, after all the posts about router bits jumping out of their collets, it happened to me last weekend. I was making a small box and using a 1/4" spiral in the table to route the bottom rabbet and the grooves to make the lid. I'm using the technique where you route a groove before assembly, then route an adjacent groove after assembly so the top slides onto the base. Anyway, after completing a groove, I noticed something wasn't right. The bit had climbed up quite a 'bit." Now, I am the world's worst at over tightening everything and I know for a fact I had tightened this thing good and tight. But it still came out. I'm using n adapter and I also take care to make sure the slot is lined up with a slot in the collet. So, far as I know, I did everything I was supposed to, but it still climbed up. It ruined my box, but no harm anything else, thank goodness. When I started routing round 2, I was a 'bit' nervous, but it went well. Oh, for reference, everythimg was clean too. I was cutting a 1/4 x 1/4 groove in walnut.
Tony
Re: Joined the club...
Tony, You didn't mention,
Keith Newton
That you made sure the bit was not bottomed out before tightening the collet.
This is the biggest reason for that problem. This should include the adapter / reducer bushing as well.
Re: Tony, You didn't mention,
Tony - Memphis
I do check that as well. I use o-rings to make sure.
Tony
Bruce, a MN Galoot
I had that problem with a 1/4" solid carbide, up-spiral Onsrud bit, used with a collet in my 1/2" router. I finally stopped using it and got a 1/4" bit with a 1/2" shank. It also doesn't chatter anymore, either
