Did I Ruin My Hollow Mortise Chisel?
David Hay Denver
Yesterday I was cutting some mortises with my hollow chisel mortiser. As I was finishing up, the last couple of mortisers ended up burning the wood a bit, with wafts of smoke occasionally erupting. When I finished, the chisel was now a nice blue color.
This isn't a tool I've used much in the past, so I may have forgotten something along the way, but I had left a gap between the drill bit and the chisel. Perhaps I need to lubricate the drill bit with something?
Have I ruined the chisel? If so, any recommendations for a replacement?
Thanks!
David
Re: Did I Ruin My Hollow Mortise Chisel?
Probably fine
John in NM
I burn them all the time, cutting a hundred or so mortises in a session - end grain no less.
I've gone so far as to put paste wax on the chisel, but I don't think it helps. The gap is more important, inefficient chip clearing increases the friction between the bit and chisel, and thus increases the heat. Honestly, I've forgotten the gap spec - under 1/8" IIRC, but bigger than you'd think.
With a long session you still overheat the chisel, even with enough gap. That is why even the cheap ones are HSS. Things do get better with use, the inside of the chisel seems to get smoother and clears chips more easily.
Helps some to dress the bit with a file and the chisel with honing stones too.
Lee Schierer in McKean, PA
Mine is a drill press morticing attachment and I've had the same thing happen from time to time. Setting the clearance properly seems to help some, but the chisels still get pretty hot. I honed the outside of my chisels and they seem to work much better going in and come out.
Lee
alternative way to run this tool
If you have a dedicated machine this isn't an option but my hollow mortiser is a drill press attachment with adjustable speed on the drill press. I run it at the lowest rpm for mortising. Considering the task I don't see why the dedicated machines run so fast.
I have bits from various manufacturers and there is a large difference in how well they clear chips. One in particular jams chips and in turn heats the drill bit.
Dave Bair
Burning and bluing are pretty standard results with hollow chisels. One thing that seems to help is to polish the INSIDE of the chisel, not just the cone-shaped area but the whole inside. It helps the drill to move out chips more efficiently.
Re: How to polish inside?
Dave Bair
Behead a thin bolt and cut a 1" slot in one end, thread sandpaper through the slot and wrap it around bolt. Use a hand drill to spin the spin the bolt as you move it back and forth on the inside of the chisel. When the sand paper dulls, rewrap it around the bolt in the opposite direction and go at it again.
