I need to make a ramp for a project that requires I cut a 16 degree angle along a 4 ft piece of plywood. This is the location where the ramp meets the floor. Will probably use 3/4 inch ply. How do you do this safely? Cutting the plywood standing up seems rather dangerous.
I made a jig for my fence that looks sort of like a lower case h in cross-section.
The lower part fits on the fence, loose enough to slide, but tight enough not to tip. It touches the saw top on either side of the fence. The side/upper part extends about 2' or so. I have large holes drilled into it so I can clamp boards more easily.
You mount the board, set the angle on the blade and go for it.
I use it for cutting bevels on table tops and I did use it to make a ramp a while back.
If I understand your question, you want to put a sloped edge on the ply to allow wheels to go from the flat to the inclined surface.
If that's correct, I'll advise you to leave the ply alone as it will splinter/fracture off in use. Instead, make a "nose" strip in hardwood. Your strip with an angled top surface will be easy to make with a planer and a sled/carrier that holds the stock tilted to one side to get the desired angle. The shaped piece can then be either spline-jointed or rabbited and glued to the end of the ply, tapered side down, for a durable product that will stand up to some wear.
I'm making the parts for my son's High School FIRST robotics team, to emulate the actual playing field for this years robotics competition. The ramp itself only needs to be 7 1/8 inches wide, so I can probably do the entire ramp in hardwood and not have to attach a beveled edge to sheet goods at all (except where it meets the flat platform)
I use 1\8" steel cut to the width of the ramp. I set the ramp in place and then set the steel in place and attach with wood screws (holes predrilled and and counter sunk). If you still wand to go the wood route, make the top and bottom starting sections from 12" sections of ply. Easier to work with on the TS, and as they take the most wear and tear will be much easier to replace in the future. Just my thoughts, have done both.
You can do it by setting your jointer fence to 106°. Double-face tape a straight 2x4 to your top surface flush with the edge. Run the the 2x on the fence. The jointer's cut will be a perfect 16°
Is the 2x4 that is taped on the fence to keep the jointed piece in proper position? I am assuming that the taped 2x4 position doesn't change as I make multiple passes? This does seem to be easier then the planer option.
Square up 2 adjoining sodes of the 2x. put a line of tape on the top of your workpiece back from the edge. attach the 2x so the 2nd flat surface in flush with the edge of the workpiece. You can now joint the "assembly" to put the taper on the workpiece like this
I misunderstood this. I thought you wanted to cut a taper on the tips of a bunch of planks the create a ramp by installing them side by side and that they would be too "tall' if you stood them up on your table saw.
Why don't you set the fence on your table saw to 16 degrees and rip a board? Stand the board on its edge and rip it. I have ripped any number of pieces like this. I use the back side of my fence so that the blade leans out and the sliver falls off without being trapped under the blade. I leave enough of an edge for the board to ride on.
If your saw will not reach far enough to make the cut in a single pass you can do it in two or three. Cut the first one as deep as you can, rip the sliver off, cut a second piece that matches the thick edge of the first one and glue it up. Sand it smooth.
Basically what you need is one of the jigs made for the 'scarf joint' which is common in boatbuilding. There are plenty of references online showing how it is done. I recall a nice one which used a ramp and a sled bearing a router.
Barry, I'm not following the idea on using the back side of the fence so as to not trap the cutoff under the blade? I have a left tilt saw (not that it matters). Also, the bevel needs to be through the entire edge, so I'm thinking to screw the ply to a piece of lumber to support it during the cut?
Bart, I am dyslexic or dysgraphic Or some such thing. I have a terrible time with left and right. Let me see if I can explain this without too many lefts and rights.
If your blade leans towards the fence so that the top is near the fence and away at the table, don't rip a piece like that. The sliver that caught between the table, blade and fence can turn into an arrow and shoot back with considerable force.
Position your fence on which ever side of the blade makes the top of the blade lean away from the fence. Set the fence about a 1/16" or 1/8" from the blade and tilt the blade to 16* or whatever the desired angle may be. Rip the board with it standing on its edge. Raise the blade as high as you can. (3"?) Return the blade to vertical and set the fence at 3" and rip the sliver off the edge of the board. Lets say the edge the thick edge of the ramp piece is 1/2". Repeat the set up above, this time with the fence set at 1/2" or whatever the thickness of the thick edge of the ramp is and rip the board it again. Lets say this piece tapers from 1/2 to 1" . Now you can glue the first ramp strip onto the edge of the second piece, making a piece that tapers from 1/16" to 1" and about 6" wide. if you have to you could repeat this process until you get a piece 1/16" to 1 1/2" and so on.
Wish I could draw it out for you. Maybe somebody can tell me how to draw and scan and post.
Thanks for taking the time to explain Barry. I now understand what you were saying. Since I have a left tilt saw, I use the "front side" of my fence. I did these cuts yesterday and they came out fine. Thanks everyone for your great ideas and input.
