Help! Tool Money in Jeopardy!
Robby Wright - San Marcos, CA
OK. Not really that bad, or at least I hope not. Our dryer isn't drying as well as it should. It still gets hot, but it takes two cycles to dry the laundry. I have a hunch that the dryer vent pipe is plugged up and the damp air can't escape easily.
Anybody have any easy way to clean the vent pipe? It is inside the wall, makes a right angle bend out of the dryer and goes about 8 feet to the outside wall. I believe it is the standard 4 inch pipe. There is a louvered vent on the outside wall. I have never had to deal with one more than a foot long or so.
I was thinking about connecting my Rigid vacuum to the outside vent and putting an air hose down the tube from the dryer side with the idea that the air would loosen up the lint and the vacuum would suck it up. Anyone have a better idea?
If this isn't it, my tool money is going to have to go for a new dryer. Help!
Re: Help! Tool Money in Jeopardy!
mdclor
Robby, I cleaned mine by removing the vent cap on the roof and feeding my shop vac hose down the vent. I jiggled it and pulled it up and down as much as I could to clear as much lint from the side walls as possible. I should mention that I have a flat roof and a very long hose. It seemed to help. YMMV
don stephan
Ours runs along the inside of the basement wall and I found the lint was firmly holding to the sides of the pipe. I had to disassemble our pipe. Chimney sweep rods and brush may be needed to really get it clean.
Joseph Mulherin, sr
I agree with Don. Look in the phone book and find a chimney sweep business and call them.
Send a ground squirrel down the pipe
Dick Coers
LOL It's happened twice over the last 3 years for us. They climb up about 18" on the outside basement cement blocks, opened the flap, and slide down the vertical pipe. The first one got stuck in the blower, the second one died in the pipe.
If that doesn't work, I would first check the outside flapper/louvers. I too find the lint sticks to the side of the pipe. My run is short enough to take apart. If you can run a electrical wire snake through it, attach an old t shirt and pull it back through. Think shotgun patch cleaning the barrel.
LintEater
Rik, WI
I'm very happy with a product called linteater.
We have a 18' run of solid ducting for the drier.
First time I used it I had a enough lint to fill a 5 gallon bucket.
Annual cleanings now produce a 1-2 quarts.
Also use their product to clean our wood stove chimney.
Rik
Blower
Tom Dunlap
Do you have a hand held leaf blower?
Insert the blower nozzle in the duct. Be sure to seal the duct and tubing together.
Hit the throttle. YOu could have someone watching outside with a phone to let you know that the dust is coming out and when it stops.
Tom
ben d.
I clean mine with a plumbers snake with some rags tied to the end and pull it through.
Take the vent cap off first and run the snake to where the vent pipe from the drier hooks on and pull to the outside, you can blow it out then if you like.
ben d.
+1 for LintEater *LINK*
terry quiram
I use a LintEater. It's a little spendy but works great. Run the brush in and out a couple times, turn on the dryer to blow out the loose stuff.
lint eater
use a leaf blower
Years ago my dryer stopped drying as well as it should. Like yours it took two cycles to dry a load. I took the vent apart and was astounded at how much lint I got out. Fixed the issue with the dryer, went back to work.
I also suggest the Lint-eater type thing since you can't take your apart. Lowe's carries them locally. I think the blowers and shop vac may work well but lets hope you don't blow the joints apart inside the walls. That could be a disaster in terms of moisture and mold inside the wall.
Also, the other day I noticed somebody riding around in a mini van that advertised they cleaned dryer vents. Appeared to be a franchise operation. I think it said DryerVentWizard.com I have never used them and have no relationship with them, but the point is there may be people in your area that will clean the vent for you.
And, as a Home Inspector, its a really bad idea to vent a dryer upward as you have found out. If you must, its a good idea to make the inlet behind the dryer into a Drip Leg type setup. Use a Tee in the line with the dryer coming in through the side. Have a "drop" a foot or more long below with a cap on the bottom. The lint falls into the drop and twice a year or so you empty it. Believe me, its worth it.
Maybe one half of the elements out
Doug Wolf
I had an older electric dryer once that had one half of the element burned out (loose bobby pin in the load) and took twice as long to dry the clothes.
Thanks Everyone!
Looks like I am off to Lowes to get a LintEater.
Andy Lincoln,in Dearborn MI
Another thing to check ,especially if you use fabric softener sheets in the dryer take a scotchbrite pad to the "sensors" that decide if the clothes are dry or not. Apparently fabric softener builds up and on our dryer it was sending a false reading and shutting down the heat.On our LG the sensors were inside the drum near the lint filter.
Good tip, Andy. I'll give it a look. Thanks.
Re: +1 for LintEater
Rik, WI
I run the drier w/o heat during the entire cleaning process.
I haven't read all the responses but the odds are one of your thermostats isn't working properly. that will make one of the heating elements turn off too soon and takes forever for your clothes to dry. It's an inexpensive part but you have to dissassemble almost the whole machine to get to them. At least on my dryer that's how it works.
